change the gear box light - easy way.
I check the few posts that show how to change the gear box light on the corolla and they are very complicated. Such as remove center console... etc.
All you need is a flat head screwdriver. Pop and remove the bezel with the screwdriver. Carefully pop the four plastic snap (2 on each side) of the gear box cover. Remove the bulb with your finger. Replace the bulb and snap everything back together.
Hope this help for some people since I follow the wrong way and it took me more than an hour.
