This is a continuation of my earlier ball-joint thread.
Recap: I have a clicking noise on the front left as I accelerate while turning right. Initially thought it was a ball-joint problem, but now, on advice and further investigation, I'm convinced it's a CV joint problem. I removed the wheel and inspected the CVJ to find that the rubber boot is split.
So I returned the new ball-joint and bought a new CVJ. Now, I'm no mechanical wizard, but I am the sort of person that figures that I can solve any problem plied with proper tools, a touch of common sense, and as much time as it takes. So I naively jump into these things knowing eventially I will succeed. This is no different.
Now, I have a few questions that perhaps someone out there can help with.
1. The installation insert that came with the CVJ indicates that the drive shaft assembly should be removed from the car before removing the CVJ from the shaft, so as to avoid stress to other assemblies that may need subsiquent readjustment. Is this a practical approach? I certainly do not expect the CVJ to slide off the shaft, but will it require so much exertion that it may affect other parts of the drive train if left attached? Is removing the drive shaft an arduous task?
2. Who out there has done this replair before? Is there a step-by-step? Photos?
3. What are the potential potholes
to look out for?
4. I've been unable to source a shop manual locally. I checked with alldatadiy.com only to be informed that they do not support my particular model of Corolla ('91 diesel sedan imported used from Japan). Is it necessary, or just a convenience. Any idea where I could find one for this model? Anyone with an alldata subscription willing to share the procedure for a similar model (say a '92 sedan, I think my body style is AE102)?
5. Are there specialized tools required. I have a decent set of metric sockets, and assorted screwdrivers and pliers and one steel hammer.
With your help, my tools, and my digital camera I hope to document my repair and make it available to others who need to do the same. Thanks in advance.
Paul.
