Need work to be done on the SR5 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2002, 05:10 AM   #1 (permalink)
The terrorist
View Xenon's Photo Gallery
I've been hearing this knocking noise in my car everytime I start from stop or I take a sharp turn.. Now that I'm trying to enjoy my suspension I get something to go wrong with my engine..
Fortunetly I just found out that there's a 90% chance it's my engine mounts, my mechanic told me that he's pretty sure that the bushings are worn out and I need to change the mounts, although they shouldn't be a big deal, but he has to tie the engine to the crane and life it up in order to change the mounts..
Taking the car in on Monday, I hope that's what it is.. I don't think it could be anything else either, it only happens when I take sharp turns or hit a nasty bump or pothole, and since it sounds like something is loose and playing around under the hood, I guess it makes sense to doubt the engine mounts!!
What do you think guys?
My sexy AE92 http://members.cardomain.com/ababan
Xenon is offline   Reply With Quote
Old 04-14-2002, 08:01 PM   #2 (permalink)
Banned
View goodcookiedrift's Photo Gallery
wouldn't the rubber on the engine mounts have to be virtually non-existant for it to make a clanking sound? I mean, i've seen really worn and weathered engine monts (rubbers cracking, and its dry as anything) but never deteriorated to the point where there's actual material lost.
Nick
goodcookiedrift is offline   Reply With Quote
Old 04-14-2002, 08:46 PM   #3 (permalink)
The terrorist
I guess the rubber is dry or something! I still have to find out, I couldn't tell by just looking at it, and it's impossible to move your engine and find out if it's actually the mounts that need changing, so I have to take it in tomorrow and find out if it's actually the mounts or not.. I have a good feeling it is..
Old 04-14-2002, 10:08 PM   #4 (permalink)
Banned
View Im_a_dickhead's Photo Gallery
I just got my Hachi Roku, and I think it may be that your front tires are scraping on the mud flaps. Considering that it happens when you take sharp turns. Check that out before you even go to the shop. It might save you some dough.
Im_a_dickhead is offline   Reply With Quote
Old 04-14-2002, 11:08 PM   #5 (permalink)
The terrorist
Thanks for the suggestion, but I don't have mu flaps and I know it's not that, because even when I take slight turns it happens sometimes..
I just asked one of my friends and he told me that if I go on the highway and while I'm on 5th gear to release the gas and hold the gear. If it shifts that means you're engine isn't as stable as it should be. And that happened! So I guess it is my mounts..
Old 04-15-2002, 02:39 AM   #6 (permalink)
Banned
Oh, well, I guess that could be right. You just don't wanna be spending more money than you have to.
Old 04-15-2002, 02:47 AM   #7 (permalink)
View 88corollaGTS's Photo Gallery
Could be alot worse I guess, How much would it cost to fix the engine mount?? I have NEVER heard of Mudflaps scraping on the front tires?? Has this happened to anyone?? Not flaming just asking...
88corollaGTS is offline   Reply With Quote
Old 04-19-2002, 01:01 AM   #8 (permalink)
The terrorist
Ok, I stand corrected.. It turned out to be my lower ball joints, my driver side was really bad, you didn't have to put any effor to move around! So I replaced them both and "Problem eliminated" so happy it turned out to be just that... Thanks for the help though guys
Old 04-19-2002, 02:17 AM   #9 (permalink)
My GTs went into the shop today :sad: pissing fluid like crazy. Hope it doesn't cost an arm and a leg.
Old 04-19-2002, 07:50 PM   #10 (permalink)
The terrorist
hey tell me what it was.. I just hope it's not your head gasket.. If it's anti-freeze it's probably your thermostat...
Old 04-20-2002, 01:04 AM   #11 (permalink)
Banned
won't be HG...thats a simple check...just do a comp check.
I figured it would be your ball joints or cv joints....i knew it wasn't the motor.
you can check the motor moutns by reving the engine via TB. that way you can visually check it.
Old 04-20-2002, 03:20 AM   #12 (permalink)
The terrorist
Goodcookiedrigt, I was talking about 88CorollaGTS's car!
Old 05-01-2002, 12:00 AM   #13 (permalink)
Gameroom cash: $134355
yeah, i have a 90 sr5 and my 5th does the same thing....if that were true, then it'd do it in all gears.....i dont know why mine does that though....my friend has a bad motormount on his accord....the only way you can really tell is that it shakes a little
Old 05-01-2002, 08:17 AM   #14 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Well the waterpump might be leaking, the case on my car losing coolant :razz:
Old 05-01-2002, 11:49 AM   #15 (permalink)
It was I think what they call the drift shaft seal. :grin:
