Engine Mounts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-08-2004, 11:49 PM   #1 (permalink)
View clutchmaster's Photo Gallery
Engine Mounts
If i'm using a 4age engine a 4afe 4k, would all the mounts b the same...Also would a 7afe engine or a 3sge engine b able to fit onto these mounts?
clutchmaster is offline   Reply With Quote
Old 05-10-2004, 01:43 AM   #2 (permalink)
Gameroom cash: $134355
the mounts on the chasis are the same.... the brackets on the block for the mounts are not the same (very close, but not quite). If you swap to a 4a-ge from a 4a-fe, just cut the timing cover on the 4a-ge up a bit to fit the 4a-fe bracket.... this is what i had to do... the 3rd bolt doesn't line up on the 4a-fe motormount to the 4a-ge bracket
