A few ?'s... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2004, 11:28 AM   #1 (permalink)
SR5 Rolla's Avatar
View SR5 Rolla's Photo Gallery
A few ?'s...
Well my sr5 runs fine but when i went to start it the starter wouldn't turn over. I was thinking battery, but my lights and cd player come on. I'm now thinking that the starter may be bad...My dad said check the ignition fuse(haven't had a chance yet)....I was wondering if anyone had a pics of an ae92 interior i'm tryin to get some ideas..Could you please post some if you have any? Thanks -Josh
Bubb Rubb: "When you wanna WOOO WOOO!!! It's that Woooo WOOOO!!!" "That's only in the mornin'. You 'posed to be up cooking breakfast for somebody and so... That's like an alarm clock! Whooooo!!!"
SR5 Rolla is offline   Reply With Quote
Old 05-10-2004, 01:49 PM   #2 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
The battery can have enough power to run the lights and not turn over the alternator. It's easy enough to check, just hook it up to a running car with some jumper cables and see if it starts then...
Chris Corolla S is offline   Reply With Quote
Old 05-10-2004, 01:57 PM   #3 (permalink)
SR5 Rolla's Avatar
Tried that and nothing.The starter won't even click....I know where a starter is at the junkyard.
Maybe ill check mine before I do that..What are some things I should look at for a bad starter? Thanks all
Old 05-10-2004, 08:01 PM   #4 (permalink)
Druken Postwhore
TRDragoon's Avatar
View TRDragoon's Photo Gallery
most likely your starter. you can try tapping it with a stick the contact might be loose
The AE92 Master
UniQue_N_RaRe
TRDragoon is offline   Reply With Quote
Old 05-10-2004, 08:14 PM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
My car does the same.. I think its heat soak from the manifold.. at least on the 4AGE anyways, I'm not sure about the 4AF and 4AFE's.. but the manifold gets so hot on the 4AGE that the starter won't turn after I've been on the highway for an hour. I have to let it sit there and cool down for a bit and then it will work again. Bad engineering design.
Old 05-11-2004, 02:00 AM   #6 (permalink)
Gameroom cash: $134355
on the 4a-fe starter is on intake side.... any 4a-ge can mount a 4a-fe start on it and use it on intake side but you need the plate between motor & tranny from a 4a-fe
try tapping the back of the starter with a hammer.... that sometimes can get it to start..... but it sounds like the starter might be dead if it's not even turning
take the starter out & take it to a local parts shop... most should be able to test it for you
Old 05-11-2004, 06:31 AM   #7 (permalink)
SR5 Rolla's Avatar
I went and tapped the starter with a hammer a few times....Then I held the gas down while i turned the key. The car started right up. Now the car turns over fine...Maybe signs of a failing starter...Either way thanks for the help all....-Josh
Old 05-11-2004, 11:52 AM   #8 (permalink)
The terrorist
View Xenon's Photo Gallery
I would recommend you get a starter and keep it handy. But that happened to me a couple of years ago and I tapped it with a hammer and it's been working fine ever since. Sometimes weather change or certain things cause the starter to jam, but nonetheless I recommend you get a backup starter..
Is your car manual or Auto?
My sexy AE92 http://members.cardomain.com/ababan
Xenon is offline   Reply With Quote
Old 05-11-2004, 02:28 PM   #9 (permalink)
glad someone reads my posts
Old 08-31-2004, 08:49 AM   #10 (permalink)
View Spug Eddie's Photo Gallery
Same here! Were you able to fix it?
Spug Eddie is offline   Reply With Quote
