Believe me, things can (and do) change with automotive A/C rather quickly.. If you did the conversion correctly, you would have disconnected all the lines, blew the evap,condensor and metering device with cleaner to remove ALL the oil, installed new "O"rings and filter/drier, readded the correct amount of PAG oil, pressure checked entire system, then pulled an hour vacumn before recharging with 134a. If so, any one of the connections could have a leak.
If you just did a" dump and gas" swap, your A/C won't last long. The different oils used for R12 and 134a are not compatable. Also, you probably contaminated the system with air or debris which break down into acid (which eats up the entire insides of your system).
