Air Conditioning Filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2004, 08:44 PM   #1 (permalink)
1 4/\/\ +3|-| |\|00|3
View dlichterman's Photo Gallery
Hey guys-
I just got a 98 Corolla and whenever i turn the A/C on it stinks kinda bad for a few minutes. My friend said to check the filter, but I don't have a manual or anything. Anyone know where it is located.
Also, the person before me smoked, so other than febreeze, are there any other products/tips to help it smell better?
Thanks,
Daniel
dlichterman is offline   Reply With Quote
Old 05-24-2004, 05:34 PM   #2 (permalink)
View toyotanut3717's Photo Gallery
Your 98 corolla doesn't have a cabin a/c air filter. The 2003 was the first. You could try some A/C deoderizer for the smell. You spray it in the fresh air vents outside the car.
toyotanut3717 is offline   Reply With Quote
Old 05-24-2004, 09:22 PM   #3 (permalink)
oh, crap. i wonder if those things that clip on the vents work
Old 05-25-2004, 02:34 PM   #4 (permalink)
View newbi's Photo Gallery
It'll take some doing but I found a product at my local Autozone that really did the trick for a smokers A/C. Believe the brand was Ozium. Had to remove the panel over the passengers legs to get to the heater thermistor. Couple of screws and I had a small access to the a/c plenum. This stuff came in a pressurized can with a tube so I could spray it directly onto the front of the evaporator coil. It came out like scrubbing bubbles foam. Half went there and the other half went through the vent cowling with the fan on "high". Just follow the directions. It was a pain but it really dissolved the baked on smoke crap. PS-Oh yeah, remove the thong you stuffed in the vent after the new years eve party
newbi is offline   Reply With Quote
Old 05-25-2004, 05:30 PM   #5 (permalink)
http://www.keysan.com/ksuai10.htm
thats the stuff right?
which one to choose
Old 05-26-2004, 09:06 AM   #6 (permalink)
This is the stuff, link to JCWhitney's site but I bought it locally. Need the one with the spray hose on it, just follow the instructions. The Ozium works well too but is only a temporary cure. This stuff wipes it out if applied on the evaporator per instructions.
http://www.jcwhitney.com/webapp/wcs/...&storeId=10101
Old 07-12-2005, 06:53 AM   #7 (permalink)
View ak85lp's Photo Gallery
Would this be the same process for a 2000 Corolla CE? My AC smells like mildew at first. I thought I had a filter too. I'm in Canada so can anyone recommend a similar product to spray inside the vent if needed?
Paul
ak85lp is offline   Reply With Quote
Old 07-12-2005, 12:23 PM   #8 (permalink)
115k miles
01loadedLE's Avatar
Gameroom cash: $123100
View 01loadedLE's Photo Gallery
I used odor out for my mildew smell which you spray in the outside vents by the windsheild [you can use the fogger also for smoke smell inside the car] and it only works temporarily as the mildew always grows back in the evaporator. toyota's only answer is to let the car run a few minutes before you get in it, there's no way to fix this permanently so we're just stuck with it since they wont make better evaporators that resist that problem.
01loadedLE is offline   Reply With Quote
