best sparkplugs for 99 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2004, 12:33 PM   #1 (permalink)
View hdsalinas's Photo Gallery
Question best sparkplugs for 99 corolla
I recently replaced the soparkplugs on my car. I replaced them with the same original ones (denso).
What tyoe of sparkplugs would you recomend for a 99 corolla? And would ther be a significant difference compared to the oem plugs?
Hector David Salinas
1999 Corolla CE
(American Version)
hdsalinas is offline   Reply With Quote
Old 06-10-2004, 02:39 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Denso
Old 06-10-2004, 07:16 PM   #3 (permalink)
Corollin's Avatar
View Corollin's Photo Gallery
You will not get a bigger spark from different spark plugs and you wont get more power by getting better sparkplug wires, UNLESS you upgrade your engine seriously like a turbo that would require better ignition from the spark plugs.
So if your car is stock or only has an intake OEM is the way to go.
Corollin is offline   Reply With Quote
Old 06-11-2004, 09:00 AM   #4 (permalink)
Not so noob anymore
View Rmonkey's Photo Gallery
You're in luck, I've spent some time reading about this for my '99 Rolla.
Upgrade would be an NGK laser platinum # BKR5EKPB-11. Stock plug is supposed to be a NGK #4302. I saw at my local Toyota dealer they now have iridium which is supposed to have a better burn too.
Denso #IK16 is supposed to be an upgrade as well (according to their website).
I haven't tried any as I've had to put money into other parts lately, so I can't personally vouch for better performance.
'99 Rolla
Over 400K and a few dents, some rust but still going...
Rmonkey is offline   Reply With Quote
Old 06-11-2004, 10:13 AM   #5 (permalink)
Resident asshole
Flashmn's Avatar
No use getting platinum or iridium plugs. They dont give better burn, they only last longer than copper ones.
Old 06-11-2004, 10:29 AM   #6 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
Hmm last time I checked the 1zz-fe had coil-over-plug ignition and came with irridium plugs stock.
No spark plug wires and platinum would be a downgrade.
I know that this is the case at least for the VVT-i 1ZZs, I suppose maybe the 98-99's(no VVT-i) have platinum plugs.
Chris Corolla S is offline   Reply With Quote
Old 06-11-2004, 11:02 AM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Well... I was just stating generally that upgrading to iridium/platinum from a engine that has copper ones stock is foolish. Sure if it comes stock then by all means use it. Tho, platinum would work just as well as iridium, you just gotta replace it sooner.
Old 06-11-2004, 12:56 PM   #8 (permalink)
Well, I was not expecting V8 performance from switching sparkplugs but a little bit of power would have been welcomed
So if switching from the stock sparkplugs does not make any performance difference, why the do people replace their OEM sparkplugs and wires?
Now that I remember, when they replaced my sparkplugs they didn’t gap them. I will get them check just be sure I am within specs.
1999 Corolla CE
(American Version)
Old 06-11-2004, 01:52 PM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Sparkplugs dont add any horsepower.
Because they are ignorant? Or because the original parts wore out.
