Click Click Click!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2004, 06:27 PM   #1 (permalink)
View dubblheelix's Photo Gallery
Hey folks,
1999 Corolla here.
I turn the key, sometimes I have to turn it 10, 20, 30 times.........other times I only have to turn it twice, other times it starts RIGHT up on the first try. But it just makes a CLICK.....when I turn the key. Turn back, they try again and CLICK. Each time I turn the key ALL I get is CLICK. Do this a half dozen times or so and then it dires RIGHT up.
I'm thinking a starter? Maybe loose/dirty connections or a totally new one. I don't THINK it's the battery since everything works perfect once it starts up.
Any ideas folks?
THANKS!!
1999 Corolla
dubblheelix is offline   Reply With Quote
Old 06-11-2004, 08:40 PM   #2 (permalink)
Do you wanna have a try??
View michael9413's Photo Gallery
Er... easy to determine that you battery is dead or not...
Look at the dashboard display... Battery Sign on when you start means your battery nearly dead... Is could be your key hole problem also...
Starter will give out plenty of noise if it is going to die... I have experience on that before... it is noisier than others...
Try to look at those points 1st...
Cheers
AE-101
1.5 J-Spec Engine
Original Crystal Headlights
michael9413 is offline   Reply With Quote
Old 06-11-2004, 09:20 PM   #3 (permalink)
View Dicipleofthelie's Photo Gallery
starter starter starter!
ive had this problem too...i replaced the starter and everything was normal
current car: effed up AE-82 corolla
update: she spun a rod bearing... woooo
Dicipleofthelie is offline   Reply With Quote
Old 06-12-2004, 12:36 AM   #4 (permalink)
Gameroom cash: $134355
could be the battery as well... if the battery is bad, but it runs fine once it starts going... then that just means your alt is good..... the battery might have a bad cell & not hold a charge
when it won't start, take a hammer & tap the back of the starter with a hammer..... that helps... & if it starts right up... the starter is going out
Old 06-12-2004, 12:38 AM   #5 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
If your starter isn't dead by now... it will be if you keep doing that. Get it fixed
Old 06-12-2004, 12:59 AM   #6 (permalink)
the noise is actually a relay under the dash...or at least it is on my car....
Old 06-14-2004, 01:32 PM   #7 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
It's not the battery or it wouldn't "start right up" when it did start.
it sounds like the starter or a switch or relay or connection between the key and starter...
Chris Corolla S is offline   Reply With Quote
Old 06-15-2004, 10:08 AM   #8 (permalink)
View turbocamry's Photo Gallery
i've had plenty of experience with these...
it's probably your starter or the solenoid inside it.
easiest thing would be to just replace it.
like toyotaspeed90 said, try tapping on the started with
a metal pole or the tire wrench a couple of times
then try to start it, if it does, then it's your starter.
turbocamry is offline   Reply With Quote
Old 06-15-2004, 10:13 AM   #9 (permalink)
Platinum Shift Customs
Hatch's Avatar
View Hatch's Photo Gallery
My mom is having this problem with her 91 Cutlass Supreme and we have replaced the starter the battery and the relay and it still does the same thing, We are thinking that there is a wire inbetween the relay and the starter that is grounding out.
Could this be possible?
Jeff
Hatch is offline   Reply With Quote
Old 06-15-2004, 08:05 PM   #10 (permalink)
Yes my friend...
I also face this kind of problem on my old engine last time...
Don't really know what is the problem
AE-101
1.5 J-Spec Engine
Old 06-15-2004, 09:03 PM   #11 (permalink)
View port69's Photo Gallery
to tell you the truth, 75% of the time on toyotas, all you need are the starter contacts. $15 for oem parts and 2-3 hours for the first timer. Alot cheaper than 100's for a new starter
D.P.
port69 is offline   Reply With Quote
Old 07-02-2004, 09:08 AM   #12 (permalink)
View TB-BMW's Photo Gallery
I am having exactly the same problem with a '99 Tacoma right now. It has been going on for about 3 months and is getting progressivly worse. Especially bad on damp or very hot days. Battery is recent and voltage does not drop when key is held after "click". I was suspecting the starter also.
TB-BMW is offline   Reply With Quote
Old 07-02-2004, 02:09 PM   #13 (permalink)
View anotherae86's Photo Gallery
FUNNY i had the same problem in my toyota truck! I was mad cause i couldn,t figure it out. GUESS WHAT IT WAS?? THE BATTERY GROUND WASN'T MAKING A GOOD CONNECTION!so i changed the ground to a fender using a screw that would make good contact and TA-DA! never had that problem again! of course u might have to reground to another location. just some input i really hope this is your problem!
WHAT DOES THIS MEAN?
anotherae86 is offline   Reply With Quote
Old 07-02-2004, 02:11 PM   #14 (permalink)
AH YES ARIZONA AND MY 1984 TOYOTA TRUCK!Those were the days!Man i have to go back!
Old 07-02-2004, 09:07 PM   #15 (permalink)
Peter's Avatar
View Peter's Photo Gallery
check fuel pump too
Peter is offline   Reply With Quote
