'99 Power Window Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2004, 03:19 PM   #1 (permalink)
View fujkamd's Photo Gallery
Hi,
I have a '99 Corolla CE, standard transmission, power windows, doors, A/C, and that's about it. It has 90,000 miles on it.
In the past 2 days, the divers side window has become stuck when I lower it. The first time, the window was stuck all the way down, and the second time it was partially down.
When it becomes stuck, the window does not move up or down at all. The other windows operate correctly. After about 5 or 10 minutes, the window will start working again.
Any ideas about what is wrong and the cheapest way to fix it?
Thanks a lot.
fujkamd is offline   Reply With Quote
Old 06-19-2004, 05:42 PM   #2 (permalink)
5SFE
Lord_Anarchy's Avatar
View Lord_Anarchy's Photo Gallery
I had the same prob in my '99 Corolla CE but it lasted for about the span of one week. It would move but as the window came half-way down, the speed of the window would slow down. Dunno what happened that fixed it up though.. It's a Toyota, it just fixed itself up... LOL..
Do you think that it could be the servo motor that's dying?
Lord_Anarchy is offline   Reply With Quote
Old 06-19-2004, 08:00 PM   #3 (permalink)
It could be. I called a local dealer (i'm working in South Carolina for the summer) and they said it was probably the motor, and it would cost $450 to replace. I'm not sure I want to spend that much though...but I may have to. I'm still looking for any cheaper solutions.
Old 06-19-2004, 08:54 PM   #4 (permalink)
View 89molavi's Photo Gallery
When stuck do you hear any noise,ie motor trying, if yes just use silicon spray on the rubber moldings. If no try the motor with giving direct current to it from the switch, it might be the switch. I hope this helps.
89molavi is offline   Reply With Quote
Old 08-05-2005, 10:02 AM   #5 (permalink)
Importanic
View importstreet's Photo Gallery
The same thing is happening to me and I need a way to fix it too. Would that be the only way to fix that?
importstreet is offline   Reply With Quote
Old 09-20-2005, 03:12 PM   #6 (permalink)
View T-Comm's Photo Gallery
2001 corolla s model having same problem.
window's motor doesn't seem to be working properly.
i'm assuming the switch is OK since the window moves occassionally, seemingly only after having the car running for a while.
still investigating.
T-Comm is offline   Reply With Quote
