88 Corolla Brake/Battery Warning Light On??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2004, 12:01 PM   #1 (permalink)
View Big Chaze's Photo Gallery
Question 88 Corolla Brake/Battery Warning Light On???
My wife has an 88 Toyota Corolla (4af, I think) and the brake and battey light came on at the same time. Her car was on and all of a sudden, all the accessories wanted to turn off.
We turned the car off, and it would not start again. I assumed the problem was the alt. since it has never been changed, so I replaced it with a new one. The car has started up fine ever since,.. but the brake and batt. light are still on. The brake res. is full just above the max line.
Should I change the battery??? When I used a voltmeter,.. it read 13v's while off,.. and 14v's while on. I turned the headlights on and the volts dipped and went back up fine.
Is the battery suppose to measure 13 volts while off?? I thought it was suppose to measure 12v's???
Could this be the problem???
Big Chaze is offline   Reply With Quote
Old 06-28-2004, 01:02 PM   #2 (permalink)
View homeguard's Photo Gallery
whats it do when you try to start it?
edit: try jumping it first also.
88 Corolla Sedan 238k miles
homeguard is offline   Reply With Quote
Old 06-28-2004, 02:44 PM   #3 (permalink)
I replaced the alt. and it started fine. It has started fine for the past week and a half. The alt is charging the battery fine also.
The car cranks and starts right up,... but the brake and battery warning lights are still on.
Now her radio wont' start,.. I'm thinking there's a short somewhere but I cant find it. Why would both warning lights come on at the same time???
Any suggestions????
Old 06-28-2004, 09:48 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
The alternator may still be bad, might be working, but not in a proper manner. Also check the regulator.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 06-29-2004, 08:15 AM   #5 (permalink)
you check all the fuses?
Old 06-29-2004, 08:23 AM   #6 (permalink)
SR5 Rolla's Avatar
View SR5 Rolla's Photo Gallery
My brake light wouldn't go off. Check your brake fluid level first. My front pads were fine, but I needed new drums in the rear so check it out.
Bubb Rubb: "When you wanna WOOO WOOO!!! It's that Woooo WOOOO!!!" "That's only in the mornin'. You 'posed to be up cooking breakfast for somebody and so... That's like an alarm clock! Whooooo!!!"
SR5 Rolla is offline   Reply With Quote
Old 06-29-2004, 08:34 AM   #7 (permalink)
i think the only sensor with the break light is on the hand break im not sure though, i am gussing this is a sedan?
Old 07-01-2004, 07:36 AM   #8 (permalink)
Yes.
But one fuse is bad,...it's the one under the hood that says "CDS".
it's one of those big peach colored fuses.
I replaced it,.. but the lightdidn't go off.
Old 07-01-2004, 07:38 AM   #9 (permalink)
Brake fluid is topped off.
I have to check the brakes themselves.
The reason I didn't,.. is cause the charging light is on also.
Old 07-01-2004, 07:40 AM   #10 (permalink)
How can I tell if is't the parking brake???
Both lights get brighter when I apply the p brake.
Could this mean something??
Old 07-03-2004, 09:36 PM   #11 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
If the break light AND the battery light come on at the same time, chances are its your alternator, I learned that recently from experience. The alternator charges about half the time and the other half it will give low charge, this is why the brake/battery light comes on, it indicates that your alternator is producing a low charge (under 12V) and eventually it will stop charging.
If the brake light alone comes on, that means that your brake fluid is low, not that your brakes are broken or anything like that.. the only sensor is located on the brake fluid bottle and that's it, there's no sensor for worn out pads/shoes(well except for the squealing spring on brake pads) or broken parking brake cables.. you get my drift?
However there is a sensor on the brake lever that turns on when you put your parking brake on, this explains why your brake light gets brighter.
Old 07-04-2004, 08:42 PM   #12 (permalink)
Well,..thats why I changed the alt. first.
But both warning lights are still on.
The new alt is charging fine. I've checked the battery once a day for the past two weeks and it measures the same volts (13v's).
I checked the battery and it's in good condition.
What else could it be??
Old 07-05-2004, 12:14 AM   #13 (permalink)
KDM is in
REN69's Avatar
hmmm.. bad ground maybe. maybe even a bad fuse.
and yes.. my alternator did charge fine.. but only half the time.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 07-05-2004, 09:33 AM   #14 (permalink)
I checked all the fuse before changing the alt.
How can I tell if I have a bad ground???
Old 07-05-2004, 10:58 AM   #15 (permalink)
CanadaGTS's Avatar
View CanadaGTS's Photo Gallery
I had that problem with my 4af also if you changed the battery and the alternator and the light didn't go away, also check the battery terminals if that still doesn't fix it then it this. its the main power wire on the postive side this same wire controls the choke on the car i think its a yellow wire, that wire is corrode or starting to break down over all the years and weather conditions like mine did so what you need to do is jump the wire from the alternator to the main power wire on the battery that way there two way for the power to get through the system. it took me 6 months to figure out the problem. it costed me 2 battery and alternator, over time is will overcharge the battery and burn the inside of the alternator. this should fix your problem like me know the outcome.
CanadaGTS is offline   Reply With Quote
