(AE86 GT-S)
I really don't intend on fixing these soon because I have designated it as my parts car but I was wondering what was causing some problems.
1. leaks oil. I know the problem to this one the hoses are old and worn out and need to be replaced.
2. loud screaching noise comming from the engine. I can make it stop by moving the car in revers and forward again. It is not there when the car is moving but apears whan breaking and idle. I think it might be a lose fan belt but I don't know because most of the belts are new.
3. broken fule gadge. I figure this might be a electical problem or the thing in my gas tank broke.
4. This one I'm at a total loss for. when I perss hard on the accelorator my exahaust will shoot out allot of water with brown and red crap in it.
_________________
1986 Corolla GT-S Hatchback
<font size=-1>[ This Message was edited by: Voodoo.Priest on 2002-05-02 00:38 ]</font>
Sounds like coolant to me, cuz toyotas coolant is red, and the brown can be the older toyota coolant (which infact was brown in coloration, or beige), or just plain rust. But I'd say you have a blown gasket if it does that, but I could be wrong too...
On 2002-05-02 00:38, Voodoo.Priest wrote:
(AE86 GT-S)
Not a big deal, unless your block is cracked.
Yep, just a belt, as people have said. Easy to fix and nothing serious.
Broken fule gadge. I figure this might be a electical problem or the thing in my gas tank broke.
Again, nothing to worry about, as long as you keep track of how much you drive so you don't run out of gas. :wink:
Now this sounds bad. Coolant in the engine is not good. :sad:
_________________
WOW I've blown alot of Head Gaskets in my time but I have never had Brown and red sludge coming out the exhaust?? :???: Does the car idle funny when you first start up in the morning?
(AE86 GT-S)
swap engine.......
swap engine.......
some one may have touched the gague in the cluster and that can cause this
swap engine.........
siu-sum loy-yun
nothing is forever æ92.FF.pilot
On 2002-05-02 20:22, trueno92 wrote:
swap engine.......
Wow a master mechanic at work. LOL!
And using this same theory if my lock on my door didn't work I'd have to replace the whole door. If there is a little dent in the car replace the body. If I have a flat tire I would have to replace the wheel and the suspension.
Oh no! Is that a paint chip!?! Now it's a write off. God no!
......swap engine.....
_________________ i currently have a stock typeR brain and it's not putting enough Knowledge. i want to ask u experts what is the best way to reach my desired Knowledge?
<font size=-1>[ This Message was edited by: trueno92 on 2002-05-02 22:46 ]</font>
The engine was swapped 5 years ago so I am doubtfull it needs to be swapped so soon.
But like I said this has been designated as a parts car and ripping it appart after I find another one. When this happens I'm going to pull the engine apart and rebuild it and then let it collect dust in my garage (if the next one has an engine).
Trueno92 is just being nice... he's just trying to not say "You bought a Lemon"
But then again a 16 year old car... anything can happen and probably will be careful not to drive too fast around the twisties or corners your car might snap in two.
<font size=-1>[ This Message was edited by: Bensa on 2002-05-03 00:22 ]</font>
I knowingly bought the lemon. The only thing I didn't expect was the broken frame. But I decided to keep it any way cuz I only paid $400 for it. I figured it was a good deal for the parts.
