I have been checking my mileage lately and it seems to have dropped to a pathetic 17mpg (city).
I made a list of things that I have been observing that may have something to do. They are connected to the emissions system and may give me some clue.
Besides de excessive fuel consumption, I have been observing the following: remember that this car has 100k miles.
1) When you turn the key it takes a second longer than what you would expect for the car to start.
2) When idling and you are outside the car there seems to be a strong "burnt gas" smell. (Like if it was burning too much gas)
3) I have observed that the car may use up to a quart of oil between oil changes. (At last oil change I switched to Pennzoil high mileage oil)
Besides this, the car runs smooth. Acceleration seems fine. The car never sputters or stalls. (Although it seems to lag sometimes while flooring it. I was used to a 4.3 V6 so this might just be
Normal for this engine)
I am planning on performing this "tune up" to the car soon:
1. Clean injectors (never done before
AFAIK)
2. Change air filter (last change was performed almost 10k Miles ago)
3. Check and gap sparkplugs. (Also less than 10k miles old but were never gapped)
4. Replace oxygen sensor (main one)
5. Check PCV (changed 5k miles ago)
6. Check computer for codes
What else could I check?
I feel that the o2 sensor may be the culprit. I read on the Haynes manual that if I were to disconnect the oxygen sensor the computer would use the default air/fuel mixture. I could try that and see if I see a difference. That way I don’t change it if I don’t have to.
I appreciatte your help.
