'90 corolla fix up help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-18-2004, 06:44 PM   #1 (permalink)
View leko916's Photo Gallery
Hello,
I am new to toyotas, but know my way around a car pretty well. I am working on fixing a few things on a friends 1990 corolla DX, just need some guidance.
1. Leaky Valve Cover Gasket - I see the valve cover is held in place by the 4 large nuts around the spark plug wells. Is there anything else that needs to come off to replace the gasket or other tips I should know?
2. PCV Valve - Where is it?
3. What is it? Does this plug go somewhere? I cant seem to find where it's mate is.
4. Thermostat - Is there anything special about replacing the thermostat, or is it pretty straight forward as they usually are?
5. Was told the car failed emissions because it is running hot. I am attributing this to the thermostat first off. Is there anythign common that I shoudl be looking for as a cause to this problem?
Overall the car runs Ok, slightly rough idle, nothing major. Just need to fix these couple of things so it can pass emissions testing.
Thanks for your help.
Robert
leko916 is offline   Reply With Quote
Old 08-18-2004, 07:34 PM   #2 (permalink)
View 1992DX's Photo Gallery
lol what are you talking about it failed because its running hot, If it was running hot the car would start smoking etc... you got a bigger problem then that. Check the o2 sensor and exhaust.
1992DX is offline   Reply With Quote
Old 08-18-2004, 08:47 PM   #3 (permalink)
Guess whos back
View CamryWhat?'s Photo Gallery
looks like your O2 sensor is disconected lol.... plug her back lol it should be near you valve cover
2000 VW Golf: CAI Exhaust 18's Koni/Nuespeed
92 Camry- No motor Stock and Stock!
CamryWhat? is offline   Reply With Quote
Old 08-18-2004, 09:31 PM   #4 (permalink)
Just repeating what I was told by the owner. I am talking hotter than normal, not hot as in overheating *shrug*
Old 08-19-2004, 01:41 AM   #5 (permalink)
Guess whos back
Your coolant then...need to be flushed.....thats it lol.....or you have a leak eeeekkk which is very bad because the head out be cracked and you coolant is leaking out of it? it could be a number of things take it to a shop....best thing to do
