4A-F question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-26-2002, 02:47 PM   #1 (permalink)
Tailgating You
View TRD 4Runner's Photo Gallery
Ok, the 4A-F is a 16 valve engine, but I see only 1 cam pully, but space (and outline on cam cover) for 2 camshafts.
I would have thought that if it is a 16 valve DOHC, it would be advertised all over the engine.
So, is the 4A-F a SOHC, or a DOHC??
Don't know, don't care, everyone is entitled to my opinion.
Lowering your car is hazardous to your health -Toyota 4Runner
TRD 4Runner is offline   Reply With Quote
Old 05-26-2002, 05:52 PM   #2 (permalink)
View kileak's Photo Gallery
Yes the 4AF is a dual cam engine. The exhaust cam is driven by the timing belt, and the intake cam is meshed to the exhaust cam by gears inside the valve cover.
kileak is offline   Reply With Quote
Old 05-26-2002, 06:17 PM   #3 (permalink)
Gameroom cash: $134355
actually (at least on my 4a-fe) if you open where you put oil in, if you look in there you can see the other gear
Old 05-26-2002, 08:34 PM   #4 (permalink)
Tailgating You
Ah! I thought that gear was some oil thingie...cool, thanks
I guess Toyota couldn't advertise DOHC because it's not a true DOHC because it only has 1 pulley instead "dual"
My friend said "this thing must have 16 lobes on that shaft!"
Old 05-27-2002, 12:40 AM   #5 (permalink)
well, it is a dohc, and a "true" one... the way the cams work is the same as a dohc.... only the gearing of how they run is differently.... which was for economical purposes (why we get better m/g than the gts)
