supercharging 4af - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-10-2004, 06:02 AM   #1 (permalink)
View gasman's Photo Gallery
supercharging 4af
hi im wanting to supercharge my 4af rolla carbed and was wondering how hard would it be and if it was even possible. im thinking of using a sc12 and using a switch to surn on the supercharger. im not inteding to run high boost just a little so least modifications needed.
cheers for any help
Brake-Down Shift-Turn
gasman is offline   Reply With Quote
Old 09-10-2004, 09:13 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
its possible, you can run it with carbs or convert to injection, both do work.
Old 09-14-2004, 08:38 AM   #3 (permalink)
View gorka's Photo Gallery
Where did you find this super charger??
gorka is offline   Reply With Quote
Old 09-14-2004, 11:40 AM   #4 (permalink)
Resident asshole
Flashmn's Avatar
well a trashed out GZE would have an SC12 or 14
Old 09-14-2004, 07:43 PM   #5 (permalink)
i got an sc12 from a agze and looking at my 4af am puzzeled at where to put it. any ideas?
Old 09-14-2004, 08:50 PM   #6 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
Do you only have the SC12? If so, then you've got a problem. The SC12 isn't like your average Jackson Racing type SC where it replaces your entire IM. Instead, Toyota put the SC as a standalone unit with the IM, SC and TB all as separate parts. This allowed them to run a IC on the GZE. Basically after your air filter, the route went TB -> SC -> IC ->IM. Unfortunately, even if you got all the equipment, you still might not be able to make it work, since all the brackets holding the SC and such are made for the G head, and you would have to make a custom IM to fit the 4A-F ports.
Then there's the problem of fuel delivery. Since you're running a carb, you've got to ask yourself: "Can this thing take boost?" If it doesn't, you've got two options: get one that can, or make a draw through setup. The problem with the draw through setup is that you're compressing air/fuel mixture. Since it's compressed, it's hot. And since it's hot, you possibly run the risk of predetonation, and grenading your engine. Mind you, I'm not really well versed in carbs, so take what I say with a grain of salt.
And how were you planning on driving the SC?
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
Old 09-14-2004, 11:23 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Well you can pressurize the carb, by taking a boost hose and putting it into the float chamber. and basically installing the SC12 would be exactly like putting a turbocharger into the car.
Old 09-15-2004, 02:49 AM   #8 (permalink)
whats a IM?
Old 09-15-2004, 08:34 AM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Intake manifold.
Old 09-19-2004, 02:35 AM   #10 (permalink)
View bluedemon's Photo Gallery
unless if you wanna save alot of space -- --you can throw in a 12volt fan ,spray a lil WD-40 on it and you might get it to boost even faster.......and it even save you money...lol j/k
bluedemon is offline   Reply With Quote
Old 09-19-2004, 09:14 AM   #11 (permalink)
Resident asshole
Flashmn's Avatar
Thats just lame
