2001 Corolla stalling - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-13-2004, 06:31 AM   #1 (permalink)
View Old Man's Photo Gallery
Has anyone had a problem with a 2001 stalling? It usually happens when I start it (not all the time). It starts fine, revs up a bit and then drops down to 500 or 600 rpm (normally around 800). Sometimes it will just die after that and sometimes not. When I try to take off with it, it has absoutely no throttle response. I've cleaned the inside of the throttle body, run a few bottles of injector cleaner through it, put in a new set of iridium plugs, and it still occasionally does it. No codes in the computer are left. Any ideas or solutions?
2001 Corolla S
It's been TRD dropped since this picture.
Old Man is offline   Reply With Quote
Old 09-15-2004, 06:37 PM   #2 (permalink)
dougone's Avatar
View dougone's Photo Gallery
Sounds like a vacuum hose has split or come off. Check around the engine. Also check for a hissing noise!
Lord give me patience - Right bloody now!
dougone is offline   Reply With Quote
Old 09-15-2004, 08:08 PM   #3 (permalink)
View hashimashi's Photo Gallery
Sorry i have no answer to ur problems, but did u change ur headlight housings? And if u did, how did u do it?
hashimashi is offline   Reply With Quote
Old 09-15-2004, 08:15 PM   #4 (permalink)
dougone's Avatar
Old man, that's a mean looking 2001 rolla btw!!!
Old 09-16-2004, 12:17 PM   #5 (permalink)
BigWilly ;)
View rated_w's Photo Gallery
mayb fuel filter/pump? my corolla has a irratic idle @ startup too.. but it didn't as of yet stall yet.
rated_w is offline   Reply With Quote
Old 09-17-2004, 05:52 AM   #6 (permalink)
Thanks for the input guys. As it turns out, besides cleaning the throttle body (with intake cleaner and a toothbrush), the MAP sensor was dirty also. Cleaning it has cleared the problem. The car has 146,000km (90,000 miles) on it and it was time. Changing the spark plugs made a significant increase in fuel milage. I was getting around 40 mpg before and now up to around 43 mpg. The manual says not to change them until 160,000km, but they were due at 145,000km. Stick with the Iridium's, even though they're more expensive. Don't forget to put antisieze on them as aluminum heads and steel plugs don't go well together for extended lengths of time. As far as changing the headlight question, no I haven't changed them. I've tried to find halo's for it, but I guess they're not made for the 2001/02's.
2001 Corolla S
