hey guys...i dunno as of late my car has been hesitating when i floor it. it sputter and sounds like its about to die. my freinds 93 stealth had a similar problem and he change the plugs and wires, now it runs fine. i had a tune up last year and they did all that. should change the plugs and wires and see if thats the problem?? any suggestions??
Thanx
Does it sttuter when you first gas it up or when it's in high RPM? Does it do it in city driving or just in certain times and RPMs? Can you give us more details!
If it doesn't respond right away and takes time for the RPM to pick up, and it comes back on the Highway (For example) then it could be your O2 sensor..
My sexy AE92 http://members.cardomain.com/ababan
Then it's your O2 sensor, go and get it checked. Or if you have the patience sit down and read your car manual, there's two terminals in your fuse box that when you hook up together you car flashs the headlights and gives you a number!
Then you find the number in the manual and it should tell you what's wrong..
Of course if you don't want to do that, then just take it to a mechanic and have him check it..
Good luck
dunno if this helps but for an 86...
When you use the diagnosis box, located by
your windshield wiper motor, and short the correct terminals, it gives you an error code which is stored into the ECU.
Short the terminals, then turn your ignition to the "on" position, and your "engine check" light will flash a pre-determined number of times. Count them, and then match it up with the book, and theres your problem.
<font size=-1>[ This Message was edited by: fatredcircle on 2002-05-30 23:25 ]</font>
geez, that was supposed to be a joke! i already know that it wouldn't flash the headlights (that'd be too annoying and mechanics/owners wouldn't like that engineering)..... so i figured there's either a light on the ECU unit (like on some acura cars), the parking lights flash, or one of the dummy lights are triggered.....
1) 1990 Corolla "SR5", part silvia, 7age.... & more 2) 1986 MR2, "MK1.22" 91 5SFE/S54 swap 3) 2010 Corolla S 5-speed (the super nice/low mileage DD - wife) 4) 1998 Camry (the boring, high mileage DD - me)
