My 4-AF Corolla has a backfire/pop whenever it is:
Under load (while driving)
around 2000-2500 RPM
accelerating from standstill
The Carb. has been rebuilt and tuned to specs. I have checked and replaced all vacum lines. The timing was set 5B with the advance line plugged then plugged back in to read 10-16 degrees so timing is set. I have 10,000 miles on the Dis.cap,wires, and plugs and just replaced ignition coil and pick-up coil so ignition is fine. I took the top of the carb off and found black all over the primary (from all the backfire). It rarely pops when reving in park or neutral, but it does rev up to about 2200 RPM and drop back down to 2000, then back up again etc...
I also put a 4'' air cleaner on top, but it still pops with stock air cleaner.
I rebuilt this 4-AF 400 miles ago so I can't see anything wrong interally.
I really want to fix the problem, but I do thing about a weber 32/36 DGEV, the problem with that is $$$ and passing emissions.
aside from the CARB problem there also a static electricity sound coming from around the transmission area. I've checked it in the dark and saw no sparking. Theres got to be a leak somewhere. Could that be related to the Pop?
Thanks for all the info
