95 Corolla - C52 swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-29-2004, 05:56 PM   #1 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
95 Corolla - C52 tranny swap
I'm thinking of swapping the 5-spd manual (C52) into my 95 Corolla, currently with the 4-spd auto (A245E).
Has anyone done this, and how did it go? Tell me what I will need for a tranny swap cause I don't know anything about it.
Also I read on Corolla Performance "TRD has a close-ratio kit for the C52 if you want to shift a lot. =) This would actually be quite nice if you could get a sixth gear."
Has anyone ever heard of this or done it?
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 09-29-2004, 07:58 PM   #2 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
^^ The 6th gear is what the C56 is for... and the close-ratio brings it upto where the 56 is minus the 6th gear.
As for the swap, you will need tranny, axles, whole new pedal assembly (Auto brake pedal too wide), clutch lines and master/slave cylinders, shifter cables, shifter, flywheel, clutch, thrust bearing, pressure plate.
The 4A/7A FE's i know you wont need an ECU as they are not transmission specific, so you wont get a CEL with your current ECU.
That should be just about it, but Let me know if i forgot anything guys.
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 09-30-2004, 01:17 AM   #3 (permalink)
Gameroom cash: $134355
you will get a cel, but it doesn't matter...... get a c52 from an ae92 gts
Old 09-30-2004, 02:03 AM   #4 (permalink)
Country Hick
thespud's Avatar
^ not on the 7A-FE ECU's... they are not Transmission specific... I know this from experiance. I have used the ECU from a friends Auto in mine, works fine. He tested his ECU with mine, worked fine. There should be no problems.
Old 09-30-2004, 03:17 PM   #5 (permalink)
Ghostridin the whip
Thanks for the info, but I decided to screw it. It's gonna be hard to get all those parts in working condition from a junkyard, and at the dealer it will cost a LOT of money. Plus, I'll be paying money to decrease the resale value of the car. It would probably be cheaper to sell my car and buy another Corolla that's manual.
Old 10-01-2004, 09:04 AM   #6 (permalink)
View cr0nik's Photo Gallery
True.
cr0nik is offline   Reply With Quote
