Is 1991 Corolla ae92 Noninterference engine? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2004, 10:09 PM   #1 (permalink)
View jenniferimai's Photo Gallery
Is a 91 Corolla ae92 a noninterference engine? How often does the timing belt need to be changed? I know the dealer manual says 60,000 but how true is this?
jenniferimai is offline   Reply With Quote
Old 10-01-2004, 10:13 PM   #2 (permalink)
Immortal
View Kwanza's Photo Gallery
Re: Is 1991 Corolla ae92 Noninterference engine?
I believe the engines are, both the 4AGE and 4AFE. Dealer reccomends timing belt change between 60k miles and 100k miles. Anytime between there is goond, and do the waterpump while you're at it.
It's ok to be naked, girl... I'm an Artist!
95 AT200 Celica ST: Stockish Daily Driver
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with JDM Smallport 4AGE and goodies...
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with Silvertop 20 Valve 4AGE
91 SW2X MR2 N/A: Rare hardtop cruiser
Kwanza is offline   Reply With Quote
Old 10-02-2004, 12:54 AM   #3 (permalink)
Gameroom cash: $134355
you can probably go 100,000 miles..... the 4afe and 4age are both non interference....
Old 10-03-2004, 07:21 AM   #4 (permalink)
View cobrajet25's Photo Gallery
I have also heard that both the 4A-FE and 4A-GE engines are non-interference, but this fellow disagrees....
http://skillcentre.com/toyota.html
Hmmm.... The timing belt is cheap enough to replace in either case (being stranded would suck nearly as much as being stranded AND chunking all of your valves). I think that I paid $18 for mine, but obviously you have to remove most of the front of the engine to get at it. I recently did this on my Corolla, and it is pretty easy. Time consuming, but easy. Mine was about ready to break when I changed it...probably would not have gone another 1000 miles! If your car has PS and AC like mine does, the good news is that neither the PS pump nor AC compressor has to be removed to change the T-belt. Just take the accessory drive belts off. It is necessary to remove the motor mount that goes through the timing cover ('cuz it also goes through the timing BELT), and the engine has to be supported with a jack or something while the mount is removed. The crank bolt is kind of a bitch to get off. I personally think that T-belts succumb more to age rather than to mileage, but it is a good idea to change them when Toyota says to. After all, they designed the damned thing, right? Good luck. Regards, Aaron
cobrajet25 is offline   Reply With Quote
Old 10-03-2004, 11:51 AM   #5 (permalink)
View ratboycom's Photo Gallery
dont forget to replace your crank and cam oil seals while you are at it, that way you wont have to tear it down again to replace them when they leak
ratboycom is offline   Reply With Quote
Old 10-03-2004, 08:44 PM   #6 (permalink)
Thank you for the advice... I've also heard something about relplacing 2 tensioners. Is it also a good idea to replace the tensioners or does that really depend on the car/condition? Does anyone know more detail about these?
Old 10-04-2004, 06:28 AM   #7 (permalink)
After you get the t-belt off, spin the tensioner and check it for wobble. If it spins smoothly and has little or no wobble, I'd go ahead and leave it alone. If you are in doubt about it's condition, change it. Good luck. Regards, Aaron
