88 sr5 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2004, 10:39 AM   #1 (permalink)
View 98RACE's Photo Gallery
88 sr5
I just bought an 88 sr5 to use for Ice Racing. I am having a hard time finding much info on this car.
I have found out the basic stuff now but I cant seem to find any after market stuff like cam's or carbs.
If any one has any info on mods or any tuning to helpout with power let me know.
Thanks
Dave
98RACE is offline   Reply With Quote
Old 10-04-2004, 10:52 AM   #2 (permalink)
View KAUAI KANE's Photo Gallery
what motor is in it if its a 22r/e then try lcengineering.com or club4age.com
Nobody dies a virgin... eventually life screws us all
KAUAI KANE is offline   Reply With Quote
Old 10-04-2004, 10:57 AM   #3 (permalink)
From reading things.
It is 1.6L 16 valve, DOHC @90hp
That is all I know. I dont know the motor name.
Old 10-04-2004, 10:57 AM   #4 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $249101
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
you have an 4afe? or a 4ac? you can do a 4age swap or do what talisman did and bolt on 2 dcoe weber carbs to it.
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 10-04-2004, 11:00 AM   #5 (permalink)
yeah dual side drafts would be good buti would suggest atleast a mild cam and some sort of ignition to
Old 10-04-2004, 11:04 AM   #6 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
The 88 4A-F should have the 4A-F engine. The F variant of the engine doesn't have too much aftermarket support in terms of cams and the like. Sidedrafts are a good start. Flashmn on this board has had success with that sort of setup.
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
Old 10-04-2004, 11:06 AM   #7 (permalink)
also one thing to keep in mind is it is a bitch to properly synch. those duals if you do not have the proper tools
Old 10-04-2004, 11:37 AM   #8 (permalink)
After a little more reading and searching I was able to find out it should be a 4AF motor.
Also what are sidedrafts? Where to find them? This is the frist carbed motor I will be working on for racing.
What about timing is there a desierd deg for best proformance?
Or adustmence on the stock carb?
Old 10-04-2004, 01:51 PM   #9 (permalink)
Does any one use web cams?
88 celica alltrac
89 celica alltrac
89 SR5
Old 10-04-2004, 07:00 PM   #10 (permalink)
4Aaron GE's Avatar
Yowza, I should really proofread my posts....
anyways, sidedrafts, I think just refer to the way the air enters the carb. What you have stock with the ring filter is a downdraft, since the air goes down into the carb. A sidedraft is similar to what you might find on a speedbike, where the air goes through from the side of the carb, and across into your intake ports.
