1997 DX oil leaks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-25-2004, 03:44 PM   #1 (permalink)
View area51's Photo Gallery
1997 DX oil leaks
I've noticed oil leaks around the engine, particularly around the head gasket and valve covers.. I've tryed tightening the valve cover gasket down, and it help the leak some, also I checked the coolant and it's pretty dark, I'm not sure if there is oil in it.. it has around 107k miles.. does these normally get oil leaks around this time or? uses about 3/4 quart every 3k miles
1997 Toyota Corolla DX
area51 is offline   Reply With Quote
Old 10-25-2004, 04:32 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Well you cant really see the headgasket.. but the valve cover seal, if its leaking just replace it. also another typical leak place is the distributor O ring.
Old 10-25-2004, 08:42 PM   #3 (permalink)
View ratboycom's Photo Gallery
it may be leaking from the cam and crank seals also, if you change the valve cover gasket dont forget to seal (with RTV) the edges where your cam and distributer come out of the cover
ratboycom is offline   Reply With Quote
