Headlight harness - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-25-2004, 08:05 PM   #1 (permalink)
View bmw5002's Photo Gallery
Headlight harness
Is it true that the headlight harnesses can burn out? I have a '91 corolla and my lo-beams don't work. Checked the fuses, relays, headlight switch. Only thing I can think of is the harness now. I read on some other threads that they can burn out. Do they burn out with stock headlights or higher power ones? I only have stock lights.
bmw5002 is offline   Reply With Quote
Old 10-25-2004, 08:32 PM   #2 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
If anything could be damaged by heat it would most likely be the socket that holds the bulb, But the chances of both failing at once is not real good.
The test lights with the sharp tip / alligator ground clip and clear handle w/bulb inside are good for troubleshooting.
Have you tried to wiggle the switch and the connectors at the combination switch ??
My 91 Prizm had some strange electrical intermittents (but none as major as this !!) I think the headlights are fused individual so it could be further back towards switch.
CW
CraigW is offline   Reply With Quote
Old 10-25-2004, 09:00 PM   #3 (permalink)
i installed a new combo switch (well, used from junkyard)
