Is it normal for an engine to lose coolant? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2004, 12:45 AM   #1 (permalink)
View nextbillgates's Photo Gallery
I topped off my coolant a few weeks ago because it was running low, and today, I noticed that a small, but noticable amount of it was gone.
I haven't noticed any leaks or seen any white smoke from my exhaust, although that may have been hidden by the rainy weather recently.
I have noticed that the engine is running a bit rougher than usual, but again, that could be due to the colder weather.
I've got a little over 40,000 miles on my engine.
2002 Corolla LE
To do list:
Repaint hood
Full brake overhaul
Get lightweight alloy rims
Upgrade sound system
Current top MPG: 33MPG
nextbillgates is offline   Reply With Quote
Old 10-28-2004, 06:24 AM   #2 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
The coolant level in the tank may never be rock steady (due to temp changes) What I do is mark the full line on the overflow tank with a sharpie, Then bring the fluid level to the mark when the engine is at temperature.
Then you can just glance down and make sure its is at the top mark when checking fluids.
CW
CraigW is offline   Reply With Quote
Old 10-28-2004, 10:15 AM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
might be the headgasket... the coolant shouldnt be below the low mark.
Old 10-28-2004, 10:59 AM   #4 (permalink)
CW
I can understand tempurature variances when checking coolant level when the car is cold, but I thought that when the car was completely warmed up, the coolant is the same tempurature regardless of what the ambient tempurature is
2002 Corolla LE
To do list:
Repaint hood
Full brake overhaul
Old 10-28-2004, 11:41 AM   #5 (permalink)
You could also use the lower cold level as a reference point if you always checked it cold. For me it is easiest at the hot/top level.
Why does the level vary with outside temps I dont know ! It is not a great amount.
Keep a close eye on it by all means.
CW
