Simplest Exhaust setup for AE92 Sedan. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2004, 01:12 AM   #1 (permalink)
View Phreshnphunky's Photo Gallery
4-AF engien, AE 92 sedan, and looking for the most economical exhaust setup for my vehicle.
COULD redo system with stock exhaust setup, but i thought why bother when i could simply get "some" kind of performance upgrade yah know?
all in all, any suggestions?
I dont bite styles, but I do bite nipples, if she is freaky.
Phreshnphunky is offline   Reply With Quote
Old 11-01-2004, 12:06 PM   #2 (permalink)
View Midnight GSI's Photo Gallery
2 1/4 piping w/ 18in. resonator and a Magnaflow muffler.
Sounds mean and flows more than you'll ever need.
C-YA!!
Midnight Motorsports
86 Corolla GTS- race/drift-flipped & waiting to be fixed
88 Corolla GTS- race/work-broke & waiting for high comp block
88 FX-16 -daily 4 now
93 Toyota Truck - Tow/Play
03 Matrix - Family
www.Millenniumautosports.com
Midnight GSI is offline   Reply With Quote
Old 11-02-2004, 06:35 PM   #3 (permalink)
View automatic's Photo Gallery
Lightbulb
Well, here's my simple solution that actually made some difference anyways; I cut a hole in the back of the stock muffler, to the left of the original outlet, then screwed on an old downpipe/manifold flange w/a homemade gasket.
You can't see it unless you bend down and look under the car, and it sounds like a decent sport system, not rumbly/blaring at all.
There's a passage inside the muffler that dumps over on the left side, so by placing another outlet in front of it you eliminate one baffle, and the restriction of the stock outlet tube, which is quite small.
automatic is offline   Reply With Quote
Old 11-06-2004, 07:28 AM   #4 (permalink)
I don't suppose a 93+ corolla exhaust would fit an 88[ae92] would it?
Old 11-20-2004, 04:39 PM   #5 (permalink)
The later cars are pretty similar to the ae92s, but the floor is 1.5" lower in the newer cars, so the hangers won't line up, or if you use them, the pipe will hit in the rear.]
I'm looking now for a less-used system in my local junkyards since my pipe cracked off in the rear the other day.
Any luck w/yours?
