how do i bleed my brakes? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2004, 01:23 AM   #1 (permalink)
View JDAN's Photo Gallery
hi there, i have a AE92 corolla and want to replace my brake fluid. Could someone post some basic instructions/tips on how i go about bleeding the brakes on my car? Thank You.
JDAN is offline   Reply With Quote
Old 11-02-2004, 01:31 AM   #2 (permalink)
View halforc's Photo Gallery
http://www.autozone.com/servlet/UiBr...3d8016c269.jsp
go to your local walmart and in the pets department there will be these tubes used in fish tanks that work perfect and are real cheap.
halforc is offline   Reply With Quote
Old 11-02-2004, 08:33 AM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Two friends, one in the car and one at the caliper. The one inside the car pumps the brakes few times and then keeps the pedal to the floor, then the other one opens the valve on the caliper, lets the air out (until fluid comes out), then closes the valve. After which the guy in the car lets go of the pedal. Repeated few times at every caliper.
Old 11-02-2004, 07:27 PM   #4 (permalink)
Okay, thanks, that makes sense. My only other question....where on the calipers do i find the bleeder plug on an AE92 corolla?
Old 11-02-2004, 07:42 PM   #5 (permalink)
View Tinooe's Photo Gallery
i believe its at the back behind the calipers.
1986 Kouki AE86
Tinooe is offline   Reply With Quote
Old 11-02-2004, 08:33 PM   #6 (permalink)
Dis reg!
AEugene86's Avatar
View AEugene86's Photo Gallery
I didn't even use the tubes, just let it squirt onto a rag, until you see a clear stream, then close the plug. make sure to top off the master cylinder though.
'87 Corolla GT-S HB
AEugene86 is offline   Reply With Quote
Old 12-02-2004, 11:09 AM   #7 (permalink)
View TototaGeek's Photo Gallery
You only need the tubes if you are bleeding the brakes with one person!
TototaGeek is offline   Reply With Quote
