cam sensor
need help!!!
I had a 1996 corolla with the 4AFE 1.6L, with the crank sensor, I had to replace the engine, the only engine I could get at the time, had no crank sensor, so I took the oil pump and sensor of the old engine and put it on the new one, so it now has a crank sensor, but on start up I got an engine fault, it says the CAM sensor is not working, the engines runs ok but it looses power under load and sometimes it surges. Any one know if the engine with the crank sensor, and the one with out the crank sensor have different cams?? Or know of any other reason for the CAM sensor suddenly not working.
Any help would be greatly appreciated. Martin.
