when idling car shakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2004, 12:16 PM   #1 (permalink)
View CodyjCA's Photo Gallery
When i am stopped i idle at just around 8500, and every 4 sec or so it will go down to 5000 and the car kinda moves around then it goes back up and it does that over and over.
i susually give it a little gas while hilding the break, that stops if from shaking around.
i have a carb, anyone know exactly whats going on?
CodyjCA is offline   Reply With Quote
Old 11-02-2004, 12:29 PM   #2 (permalink)
View jumpshotjonny's Photo Gallery
The same things happens to me, when idling at a stoplight or something the car will shake like you said every couple of seconds, seems to do it more when the car is cold. Also, if I leave it idling in park more than a couple of minutes it starts idling high then going back down over and over again. I have an '86 Corlla carburated as well. I don't know whats going on but I'd like to find out.
jumpshotjonny is offline   Reply With Quote
Old 11-02-2004, 01:12 PM   #3 (permalink)
View Limnos's Photo Gallery
Idle at 8500? My car idles at 600.
I found this link to something that might help you: groups.google.com/groups?hl=en&lr=&ie=UTF-8&safe=off&threadm=Pine.BSF.3.96.981215065621.2859 B-100000%40soda.CSUA.Berkeley.EDU&rnum=3&prev=/groups%3Fq%3D81%2Bcorolla%26hl%3Den%26lr%3D%26ie%3 DUTF-8%26safe%3Doff%26selm%3DPine.BSF.3.96.981215065621 .2859B-100000%2540soda.CSUA.Berkeley.EDU%26rnum%3D3
1981 Corolla Wagon, 5-speed, 159k miles-- my winter wheels
1981 Corolla Wagon, AT, 125k miles-- my summer wheels
** I replaced a horn. Isn't that mod. enough? **
Limnos is offline   Reply With Quote
Old 11-02-2004, 09:37 PM   #4 (permalink)
View ctrigger's Photo Gallery
UHHHH!!! 8500? I think u r mistaken. Maybe 500!! Because mine idles at 500 rpms then jumps to about 7-800 rpms! It started happening after i installed a CAI but mi9ne is a fuel injected 04 corolla s. It's simmered down a bit and my check engine light hasn't come back on since i re-installed my old stock filter! But, it still shakes rattles and rolls!!!! Confusing man i don't know what the deal is. I'm taking mine to the toyota dealership sometime this weekend to find out whats wrong.
ctrigger is offline   Reply With Quote
Old 11-04-2004, 02:03 AM   #5 (permalink)
ah yea my mistake, its aroud 850, my car has never idled at 500, should i get it retimed?
Old 11-04-2004, 09:58 AM   #6 (permalink)
View NDR008's Photo Gallery
yes, got get it checked, could be the idle jet or something is clocked.... just go to a good carb mechanic. If it was an ECU car it could be serious, but being carb.... should be a small thing. Flashmn might give a suggestion...
You shouldn’t drive for the thrill, but for the pleasure of tasting the control…
NDR008 is offline   Reply With Quote
Old 11-04-2004, 01:07 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
It might be a busted o2 sensor if it was an EFI car
It shakes because the engine RPM falls down so much, what I would check is the timing, the hoses that go to the distributor cap vacuum advancer. See if those are ok. If they are, then I'd go check the throttle pot on the left side of the carb, thats what holds the throttle slightly when you release it. If its adjusted too low, the rpm would slowly creep the low level.
oh and hows the fuel filter, changed it anytime soon?
Old 11-04-2004, 04:21 PM   #8 (permalink)
i changed the fuel filter about 4 months ago
