Q: did you reset your battery after you installed your intake?
If you didn't you need to do that.
-To make the light go away, just unplug your battery for about half an hour to an hour and the plug it back in.
-Tighten all hoses and rings, make sure there are no air leaks. The best way to tighten all the air hoses is to use zip ties.
If all that doesn't work then take to a shop and get a reading from your E.C.U; but to save time and money I suggest doing that first, I did it and all my problems with the intake went away.
Life is a game, play by your own rules.
