first take off your intake (box and hose), jack the car up and take off the two power wires (one is a clip on the other is bolted on, ALSO VERY IMPORTANT DISCONNECT THE BATT, i fried my self before doing a starter because i forgot to turn off my battery (i have a circut breaker because the batt is in the trunk) then take the bottom bolt off (14mm i beleive), go to the top of the car take a 14mm wobble socket or a 14mm socket with a wobble extension and take out the top bolt, the starter should drop but its a bit of a bitch to work it out from under the car, just try to fit it between the axle and through the side of the car
