Compression indicate the health of the engine. You'll kill the engine if you boost one that can't hold pressure.
True, it is...but you wont directly kill the engine, you'd get alot of blowby, which would basically kill your oils. (you cant exactly run a closed breather with a turbo, like you can do with an NA), which would kill the engine.
9.5:1 is boostable, just I wouldnt run very high boost with the 4A-F connecting rods, they arent exactly meant for boost applications. However, keep moderate boost and you'd be fine.
And detonation is dangerous with whatever compression you have. Just the tendency to detonate is lower with lower compression.
