Hey guys, what i need is a couple parts for a buddy of my mine that is doing a crazy conversion on his 98 corolla....what he is doing is dropping ina 20 valve 4age....he needs some parts and iw as wondering if any of you knew where to find them. The parts he needs are as follows:
Map sensor for 4age Silver Top 20 valve out of the Levin
I also need a couple Distributor caps and rotors for the same.
Also if anyone has an English Service Manual for a 1994 Toyota Levin 20 valve!!!
I need these parts bad and anyone who can helps me find them or has them would really help! Thanks guys,
-Won Eye-
TRJ
"You gotta learn ta crawl before you can walk, and driving 160MPH straight is a walk in the park comapred to driving 90MPH sideways towards a wall!"
The silvertop 20V were all AFM. If you plan on using the Silvertop 20V ECU... then you'll need the 20V Silvertop AFM. If you use the blacktop ECU, then you'll need a Toyota MAP sensor. I believe most of the Toyota map sensors are the same. People have used 5SFE/7AFE map sensors and such successfully to do MAP conversions on 20V motors. As for the distributor... you're gonna have a very hard timing finding one of those. try asking around on club4ag.com...
Do a google search for Phil Bradshaw's page. He has basic breakdowns of Silvertop ECUs and various diagrams...
__________________ It's ok to be naked, girl... I'm an Artist!
Thanks kwanza all is appeciated, as for REN69, there is no need to critisize other peoples work. And by the way, there aren't too many people out there that have done this conversion. Also being done is a Levin front end and rear end conversion. But thanks anyways...all is appreciated!
-Won Eye-
TRJ
Its not my car and should be closer to 200hp ATW. Will post dyno results after!!
-Won Eye-
TRJ
I have a 92 mr2 na and jsut bought 3rd gen Turbo rear clip, that will be fun....
-Won Eye-
TRJ
Originally posted by Kwanza The silvertop 20V were all AFM. If you plan on using the Silvertop 20V ECU... then you'll need the 20V Silvertop AFM. If you use the blacktop ECU, then you'll need a Toyota MAP sensor. I believe most of the Toyota map sensors are the same. People have used 5SFE/7AFE map sensors and such successfully to do MAP conversions on 20V motors. As for the distributor... you're gonna have a very hard timing finding one of those. try asking around on club4ag.com...
i agree with Kwanza... if you have a hard time finding the dizzy, maybe try a non-distributor set-up. but it'll bit a much more expensive route.
FYI: someone told me that the GM map sensors are BEST to use with the 20V.
__________________ 1982 Toyota Starlet (SP61) boosted since 2007
mods being done are td-03 turbo (for now), front mount, toda cams, cam gears, full 3 in. echaust w/ dp,sup AFC, custom turbo manifold, easily approaching 225 at the fly!
O and minus AC and PS
-Won Eye-
TRJ
How hard is this swap? What mounts did you use? Which trans? Axles? I have been looking into doing the same to my 99 rolla but can't find any info on someone who has done it. Where did you get your 20v from? I have been looking at several on Ebay but just a little worried about gettting an engine that I have not personally looked at. Got burned on the last used "LOW" mileage engine that I got. Good luck on your project and will be looking for your results.
thanks WD
ps Its my daily driver and I do a 120 miles round trip to work everyday SO gas mileage is also a concern. Does anyone have any mileages numbers on the Silvertops in stock form? thanx again WD
Here is a link that has an english version of a Blacktop manual it will not be just like the Silvertop but it will be at least something close. Its seveal pdf files broken up into different sections, Engine Mech, electrical, service specs, EFI, etc. Hope it helps.
Found it on this site http://www.onthenet.com.au/~paulp/Blacktop/
