how to replace headlight bulb toyota corolla? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2004, 02:44 PM   #1 (permalink)
View toyotapad's Photo Gallery
Hi All,
I want to replace headlight bulb for Toyota corolla 99. Can someone guide me, as to how to replace the headlights (right side)?
I tired to unplug but with no luck. Is there a way to remove it?
I bought the light from dealer. I know if i go to mechanic they will charge min $25.
Thanks in advance
PAd
toyotapad is offline   Reply With Quote
Old 11-13-2004, 03:30 PM   #2 (permalink)
Lives For The Curves
View nort0188's Photo Gallery
for even considering going to a mechanic to have a lightbulb changed!
Look in your owner's manual. If it's a 9006, unplug the wiring from the bulb, twist bulb counter-clockwise, pull out. Installation is the opposite.
If it's an H4 (or something like that), those suck. Look in your owner's manual, cause I don't remember those.
If torque actually won races, wouldn't we all be driving diesels?
nort0188 is offline   Reply With Quote
Old 11-13-2004, 08:51 PM   #3 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
Check out your other post...all the info is there....Raddman Out....
_____________________________________
"I OWNED A NEW CAR ONCE, MY X WIFE LOVES IT"
_________________________________________
Raddman is offline   Reply With Quote
Old 07-14-2011, 02:16 PM   #4 (permalink)
View Chaotiklown's Photo Gallery
99' Corolla Headlight Replacement
Ok guys, so it's not quite so easy... I have a 99' Corolla, and let me tell you it was a pain -.-. After going through that, I figure why not let the next guy skip the figuring-it-out process?
Specifically, this is to change the driver's side bulb which has the battery in the way. Whether the regular lights or brights are out, it is the same bulb with two filaments.
THE PROCESS
Step 1: Remove the ridiculous bar holding the battery down, take off the terminals, and set the battery someplace where you won't lose it...
Step 2: Unplug the terminal from the back of the bulb; Wiggle it a bit and it comes straight off. Once that's off, you'll see the three prongs coming from the back of the bulb.
Step 3: There is a big, fat rubber boot over the entire thing... Don't be afraid to yank on it, it's the only way for it to come off; Slide it straight back, you may have to dig your fingers beneath it to pry it loose.
Step 4: Once the rubber boot is off, set it aside where you won't lose it, and you'll be able to see the assembly holding the bulb in place.
There are three small black screws holding down what looks like a bent-up paper clip to the back plate of the bulb.
Step 5: Remove ONLY the little screw holding the clip in place. It's the one that's furthest to the left(driver's) side of the car. Be extremely careful not to drop it or you'll be fishing that little screw/clip out of the engine area.
Step 6: Once the clip is off, the headlight bulb should basically fall out, but if it doesn't just give it a little tug.
Step 7: Put the new bulb in place. Ensure the bulb is right-side-up, hold it down, replace the paperclip thing the way you too it off, and put the screw back which holds it down.
Step 8: Slap the rubber boot back on, and press all of the edges so it's secure- Pay close attention to the bottom, it's a bit tricky to reach with your fingers.
Step 9: Once the boot is back in place, plug the female terminal back onto the bulb's prongs.
Step 10: Figure out where you put the battery, stick it back in, and replace the terminals. You may want to leave off the doofy bar assembly which is meant to hold it down- It's not necessary.
Step 11: Test the lights before you close the hood, shut it, step back and pray that the light never goes out again.
If I missed something obvious, lemme know and I'll edit this.
Chaotiklown is offline   Reply With Quote
Old 07-14-2011, 02:36 PM   #5 (permalink)
nitronate33's Avatar
View nitronate33's Photo Gallery
how many toyotanation users does it take to change a lightbulb?
2005 Toyota Solara SE 2.4L
2004 Subaru Impreza WRX 2.0L
2011 Ford Mustang Shelby GT500 5.4L
nitronate33 is offline   Reply With Quote
Old 11-08-2011, 08:43 PM   #6 (permalink)
View greenjelly's Photo Gallery
No need to remove battery
I just replaced the headlight bulbs on my 2004 corolla. I did it without removing the battery. There is a small gap between the frame and the battery through which you can access the light terminal. There is just enough space to stick your forearm in and twist it out. It was a little more difficult to put it back in, but I was able to do it with some trial and error. This worked for the low beam light. But I'm guessing it would be more difficult for the high beam light, as that is right in front of the battery (I didn't have to replace it). Again, this is for the 2004 Corolla, dunno how different it is for other models.
greenjelly is offline   Reply With Quote
