AE92 Front Sway Bar Bushings - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2004, 03:03 PM   #1 (permalink)
View 91corollagts's Photo Gallery
(New owner here of a 1991 Corolla GTS) Nothing found about this on "Search", so....
Is it my imagination or does the front sway bar frame attachment also hold the rear of the front control arm in place?
If so, can I just loosen it enough to try and get new bushings installed, or is it more complicated than that?
AND, while I'm at it, who makes some poly front bushings for the stock front sway bar?
Any and all advice appreciated.
Thx from Glendale AZ.,
S Meyers
91 Corolla GTS
02 RSX-S
66 Valiant V-100
91corollagts is offline   Reply With Quote
Old 11-13-2004, 04:49 PM   #2 (permalink)
View automatic's Photo Gallery
I recall putting the sways on my '92 without removing anything else, probably want to support the suspension with a jackstand.
Nice car, like the Dart too.
automatic is offline   Reply With Quote
Old 11-14-2004, 02:21 AM   #3 (permalink)
View ratboycom's Photo Gallery
it should be like 2 or 3 bolts holding a piece of metal that holds the bushing in place, you shouldnt have to remove the control arm and if the new bushing is cut you should be able to slide it over, also i can mold poly sway bushings if needed, as well as urethane motor mounts
ratboycom is offline   Reply With Quote
Old 11-14-2004, 03:09 AM   #4 (permalink)
View ssrrww's Photo Gallery
i'm not sure if GTS uses the same front swaybar as the one used by AE92 Sedan.
My AE92 sedan requires removing the lower-arm bracket first. What is more vexing is that removing the bracket causes slight change of alignment settings. Sometimes, if you're unlucky, you have to do alignment again.
ssrrww is offline   Reply With Quote
Old 11-16-2004, 06:01 PM   #5 (permalink)
Danno
View 89yotarollagts's Photo Gallery
im thinking about replacing the whole thing are the newer sway bars off of like a 91 gts better than the ones off of my 89 gts... ??? what would u charge to "poly" the bushings lol
Thanks
Dan
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
89yotarollagts is offline   Reply With Quote
Old 11-16-2004, 11:27 PM   #6 (permalink)
the sways off the 89 and 91 are pretty much the same, also the bushings will be completly new solid polyurethane ones, price is dependent on dificulty for me, altho it wont be too hard, i just have to make a cast mold and pour some urethane into them, that and ill need a template, luckily the molds are re useable so i can make a set for myself too
Old 11-17-2004, 10:28 PM   #7 (permalink)
Danno
what kinda Mulah we talken $$$$
