Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2004, 02:38 PM   #1 (permalink)
View TRDemon's Photo Gallery
Unhappy Question
Hey guys its me again, i have a 4AF engine i would like to know if it would be ok to turbocharge with the stock caburator for 3psi. and can someone tell me about this pressure box using the blow through method.
Jayspeed
TRDemon is offline   Reply With Quote
Old 11-15-2004, 02:49 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Pressurebox is a box made around the carb, with the boost coming into the box from one of the sides. Equilizes pressure around the carb.
Old 11-15-2004, 02:50 PM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Plus you'll need a fuelpump and regulator that do boost pressure +6psi.
Old 11-15-2004, 02:54 PM   #4 (permalink)
i still don't understand, and can i still use the stock carb
Jayspeed
Old 11-16-2004, 07:40 AM   #5 (permalink)
View micro214_kp61's Photo Gallery
6 psi boost on a stock AF carb? you gotta be kidding me right? how long will your carb last running a 6 psi boost?
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 11-18-2004, 11:39 AM   #6 (permalink)
hey guys where you all get the idea about me planning to run 6psi?????? i told you all from the beginning i only running 3psi not 6PSI ok. thats why i ask, is it ok to run 3psi with the stock carb.
Jayspeed
Old 11-18-2004, 12:12 PM   #7 (permalink)
View DRaKeN's Photo Gallery
Well the best bit would be to make sure everyhting else is up to the task of being turbo charged...such as exhaust, fuel system, engine internals etc etc....Maybe invest in a reco-mild upgraded carb? Might do a better job...Good luck and try and keep the rods inside the block...
Cheers
DRaKeN
No matter what I do, I always seem to run outta opposite lock at a critical point of the slide....
1988 AE80 'rolla CS Hatch
1981 KE70 'rolla XX Sedan
1989 Holden Apollo *Cough* Toyota Camry *COUGH*
DRaKeN is offline   Reply With Quote
Old 11-18-2004, 02:09 PM   #8 (permalink)
will do bro
Jayspeed
Old 11-18-2004, 02:12 PM   #9 (permalink)
thanks for the info bro, and i'll try to keep the rods inside
Jayspeed
Old 11-18-2004, 04:03 PM   #10 (permalink)
Resident asshole
Flashmn's Avatar
The carb wont wear out running 6psi boost, how can it, it only lets in air.
But on another note, no I didnt mean 6psi boost. I meant fuel presure of amount of boost PLUS 6psi. so your fuel pressure would be N-psi/bar + 6psi/0.4bar. "N" being the amount of boost you're planning to run.
Old 11-18-2004, 04:05 PM   #11 (permalink)
Resident asshole
Flashmn's Avatar
However, your fuelpressure regulator will need to be a rising rate one, as if you have fuel pressure of 3psi + 6psi on idle, you're just gonna flood the carb. The pressure has to be 6psi on idle, but when you start to get boost the fuel pressure will rise along with it.
Old 11-19-2004, 07:16 AM   #12 (permalink)
ok cool
Jayspeed
Old 11-19-2004, 09:57 PM   #13 (permalink)
how long do you guys feel that standard 4AF pistons would last with 3psi on them ??????
Jayspeed
Old 11-22-2004, 08:09 AM   #14 (permalink)
can someone answer on this one, how long can my standard 4AF pistons stay on 3psi??
Jayspeed
Old 11-22-2004, 09:56 AM   #15 (permalink)
Resident asshole
Flashmn's Avatar
I cant say for sure, I know of an 4A-FE that ran stock pistons with 15psi...
hmm, let me say that, if theres no detonation, they should be ok with 3psi, I mean 3 psi is less than I fart
