Originally Posted by 91corollagts
I have a recently acquired 91 Corolla GTS, and ordered an HKS cat-back.........
OK, it's on. Has a smaller resonator behind the cat with the larger muffler out back. It's in three pieces, resonator, mid pipe with the two 90 degree bends, and the muffler with the piece that goes over the suspension subframe. Smaller "non-ricer" chrome exhaust tip. Arrived within one day of when promised.
Sound is healthy but not loud or rude at any rpm. Diameter is about 2" from the cat to the resonator, then appears to get closer to 2 1/4" out to the muffler.
Seems to be very well made and everything bolted up well. No rattles/rubs. They only sent four bolts, and could have used six; the two factory original bolts between the cat and the first section/resonator were very corroded. Had to cut one off.
I'd give this a 10/10. Toysports stated that these might be discontinued soon.
Now if I could only finad a factory original left front strut housing I could install my Koni inserts!!! Anyone?
