Ae86 Block is it Iron?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2002, 08:20 PM   #1 (permalink)
View NACE86's Photo Gallery
I was woundering if the AE86 Block, is Iron? and how it would run with a turbo? do i need to re-enforcen the cylinder walls
NACE86 is offline   Reply With Quote
Old 06-19-2002, 10:14 PM   #2 (permalink)
View mr_sinister's Photo Gallery
it is indeed an iron block..
the gze (super charged 4age) uses teh exact same block as the red tops and 20V (slightly beefier than blue top).. so take that for whatever its worth..
mr_sinister is offline   Reply With Quote
Old 06-19-2002, 10:14 PM   #3 (permalink)
Ontario's King of AW11
View yellow86MR2's Photo Gallery
It is iron. If you run a moderate boost level, then you should be ok.
Martin
yellow86MR2 is offline   Reply With Quote
Old 06-19-2002, 11:48 PM   #4 (permalink)
since 1996
Voodoo.Priest's Avatar
View Voodoo.Priest's Photo Gallery
The Iron allows it to take a better beating so it to handle more pressure. So it can take a turbo no problem. Like I said before you should go to Club 4AG and read the reference section. This has a **** load on modding options as well as being able to tackle just about any question you have about the AE86 and the 4AGE wether it be 16V or 20V.
http://www.club4ag.com/
So go here now!!!
This is where I I found most of my information on both the AE86 and 4AGE.
1997 Corolla SD sold __________________ 1986 Corolla GT-S liftback *Christine* R.I.P.
1986 Corolla GT-S liftback *Ashley*_____ 1986 Corolla GT-S coupe *Martha* R.I.P
2005 Impreza RS 2.5
Voodoo.Priest is offline   Reply With Quote
Old 06-20-2002, 03:43 AM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
My mechanics AE100 (94afaik) Rolla is running stock internals on a 4A-FE and 15psi boost. Thats about 200hp, only problems are that the clutch slips under full acceleration, well stock clutches arent rated for double the hp, also the wheels spin momentarily when you hit full boost. due to the fact that theres no LSD. Heh, but I was riding in it last friday. HOLY CRAP it was so awesome, never felt a rolla go SO FAST!
Old 06-21-2002, 02:41 AM   #6 (permalink)
Gameroom cash: $134355
yeah, the block on a 4a-fe is the same also... yes, iron.... just the head is different.... weaker and originally built for economy.... so at least i have SOMETHING over the 4a-ge.... (like 5 miles to the gallon more)
Old 06-21-2002, 08:04 AM   #7 (permalink)
Resident asshole
Flashmn's Avatar
"weaker" <- depends really, you CAN tune the 4A-F to be a powerful engine aswell, but it takes more effort.
Old 06-21-2002, 10:12 PM   #8 (permalink)
no... i mean weaker as in from factory the top end cannot take as much pressure as the g series engines.....
Old 06-21-2002, 11:09 PM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Not true. The 4A-FE can take AS MUCH pressure as the 4A-GE, maybe even more as the compression ratio is lower.
