your gonna need the entire system, master and all, you are set up for disk/drum and you are going disk/disk. If the gts has different diameter caliper pistons on the front than you have now, your gonna need those too to get it balanced right, and if the gts calipers are needed for the front and dont fit onto the steering knuckle, your gonna need those too along with maybe the rotor. Look the car up on tirerack.com and see if it has 14 inch wheels on it, if it does, you might have to go up to 14 to keep the wheels from hitting the rotor/calipers. If you can keep your front rotors, be sure they are the same diameter as the gts rotors, or the brakes are not going to be balanced right. You are going to get a real education on braking over this.
