It might be the o2 sensor, since that can cause an error reading in from the exhaust emissions that could trigger the ecu to think that its running lean and then pump up the juice. Caused bouncy idle, bad idling, bad acceleration on the mercedes I had.
I'm not being hostile, I've just told people already so many times, maybe you few times too to check the errorcodes before doing anything else, because in modern cars the ECU watches over almost everything in the car, so if something breaks you get the info from it. Carbon build up isnt that big of an issue in modern cars and modern fuels, and carbon build up wouldnt trigger the check engine light thats for sure.
If there was carbon build up you certainly wouldnt get it out, by spraying seafoam through the sparkplug holes, you'd have to take a scraper and scrape it off, it really sticks hard to the pistons/head/valves.
