All 4 cylinders are misfiring !!!! HELP!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2004, 02:34 PM   #1 (permalink)
View ctrigger's Photo Gallery
My 04 rolla has bad o2 sensor and is misfiring on all 4 cylinders!!! Is it just the o2 sensor?
ctrigger is offline   Reply With Quote
Old 11-24-2004, 03:20 PM   #2 (permalink)
View TekPhobia's Photo Gallery
Wow...if this is the same car that you put Seafoam into the "carb" ..STOP and take it to a mehanic. You've been dealing with this car post after post and it's only getting worse.
I'm guessing when you poured Seafoam into the motor (bad move to begin with) and fired it up, there was a bit of a misfire and you set a code.
So...you've got a bad O2 sensor. It's not the cause of the misfire and it won't be cheap. Depending on which one it is (pre/post cat) you're lookin at between $100-$200 for a Bosch.
-Tim
TekPhobia is offline   Reply With Quote
Old 11-24-2004, 03:29 PM   #3 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $592957
iTrader Score: 7 reviews
View xpeed's Photo Gallery
My advice. Don't mess with the important part of the engine.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is online now   Reply With Quote
Old 11-24-2004, 03:49 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
My 04
By the way 04's dont have carbs, because they cant pass emissions with them.
You poured seafoam in the fuel tank and connected it to the throttlebody? Maybe the seafoam f'ed up your fuel injection or who knows what else.
Old 11-24-2004, 04:39 PM   #5 (permalink)
Gameroom cash: $147537
Did you wash the engine?
04 still got warranty WTF are you doing
Old 11-24-2004, 04:50 PM   #6 (permalink)
'10 XRS (05 & 09 XRS RIP)
rolla-XRS's Avatar
Gameroom cash: $105560
View rolla-XRS's Photo Gallery
Seafoam? Egad's my man...
Get your baby to the dealer and get a physical.
rolla-XRS is offline   Reply With Quote
Old 11-24-2004, 05:00 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
As far as I know, he ran it through the engine....
Old 11-24-2004, 07:58 PM   #8 (permalink)
It's not under warranty due to a hole was found in the intake tube after i bought it! It was getting trouble codes before the Seafoam brother!! The Seafoam was used as directed and no it wouldn't as far as i know mess up fuel injectors because it's made to clean the injectors!! I poured in the intake as directed and then added it to my fuel tank! Each place u put it cleans different things. By adding it to the intake it cleans Carbon fron valves, cylinders, and a couple of other things. Adding it to the fuel tank it cleans the injectors ect...
No i didn't wash my engine!!! I was told it could be my 02 and my spark plug coil!! What u think?
Old 11-24-2004, 08:19 PM   #9 (permalink)
echo1's Avatar
View echo1's Photo Gallery
Bring your car to a mechanic and ask their opinion. Maybe get two mechanics...much better. Consult and expert dude!
echo1 is offline   Reply With Quote
Old 11-24-2004, 08:38 PM   #10 (permalink)
Yeah i plan to get a mechanic to look at it probably on friday afternoon!!! Maybe it's just timing and the o2 sensor!! Thanx
Old 11-24-2004, 08:39 PM   #11 (permalink)
Old 11-24-2004, 11:23 PM   #12 (permalink)
Resident asshole
Flashmn's Avatar
Quit guessing and get an answer from a professional.
Old 11-25-2004, 12:11 AM   #13 (permalink)
No more guessing.....it's the driver
-Tim
Old 11-25-2004, 08:18 AM   #14 (permalink)
Angry
You guys are so cruel to me!! I am going to ask a professional thank you very much!! undefined
Old 11-25-2004, 08:47 AM   #15 (permalink)
Resident asshole
Flashmn's Avatar
No we're not cruel, we're realistic, you wont find the problem by yourself guessing what ever would be the reason. You need to get the codes and get the car fixed by a professional.
