Hi. I'm in Philippines and the weather is quite hot & humid around 25~33, 75RH, what specs of oil do you recommend? Mineral/Semi Synth/Fully Synth? Thanks.
"The lamest twice banned, non-female member of-all time." -Ekam, Thanks, I <3 you too! AIM/Yahoo Toysrme257th
for anything, anytime; including camry turbos Now with Turbo!
what motor do you have on the car? alot of guys with high performance motor uses 15W50 Mobil 1 Full Sythetic. if it's too expensive just use a good mineral oil and just replae it often. try 10W40. Laguna is not as bad (in traffic) as Manila so you should be ok.
welcome pare!
__________________ 1982 Toyota Starlet (SP61) boosted since 2007
I wouldnt suggest going to synthetic to mineral just like that. I'd use semi-synth in between... then again, I dont think you'd really run into any problems just putting synthetic in directly, but I think the transition might be better off doing it in steps. I think that was recommended by a motul/redline distributor.
thanks flashmn for the reminder. i'll keep that in mind.
Thsi is nuts.
Just put synthetic in it and don't worry about it. For those who know; Never use Fram filter, they are junk and have ruined many motors. (unless you like the paper elements falling apart and clogging up your oil passage ways and cardboard & useless plastic bypass valves) Wal-Mart super tech made by champion labs is much better; just stay away from 'orange'.
If you use thicker oil, your engine won't respond as well as a thinner oil recommended by Toyota. 10w-30 is fine.
If you want to know anything about oil: www.bobistheoilguy.com
welcome pare!
Whats mineral oil? I use K&N gold oil filters one of the top rated plus it has a 1 inch put on/take off nut on the bottom .....Raddman
