engine removal 1988 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2004, 03:17 AM   #1 (permalink)
Fee
View Fee's Photo Gallery
Unhappy engine removal 1988
I need some help. I am going to remove the engine from a corolla 1988, do I need to remove the gear box as well, if not do i need to drop the two half shafts. I s there anything i need to be aware of when doing this, any info greatly appreciated.
Fee is offline   Reply With Quote
Old 11-27-2004, 05:57 AM   #2 (permalink)
View cobrajet25's Photo Gallery
It is alot easier to take the engine/transaxle combo out as a unit. The halfshafts will need to come out, but not completely. You will have to disconnect the ball joints and the tie rod ends. Then you can just pull the axles out of the tranny while leaving them attached to the wheel hubs. The ball joint attaches to the lower control arm with three small bolts (IIRC), so no pickle fork or puller is necessary. You will, however, need to use a tie rod end separator for the tie rods. I have heard of people getting the shafts out without taking apart the tie rods, but I have never tried it. Once all of the plastic covers are removed from the lower engine bay, most of the engine parts are really easy to remove. There are 4 mounting points...don't forget the center engine/trans mount that goes into the crossmember. The bolts securing it are hidden under a plastic cover and are easily overlooked. The 4A-FE in the '90 Prism that I used to own was one of the easiest that I have ever changed. Regards, Aaron
cobrajet25 is offline   Reply With Quote
Old 11-27-2004, 01:38 PM   #3 (permalink)
Fee
Wink Cheers Aaron
I will go and give it a wirl, let you know how it goes
Old 11-28-2004, 01:10 PM   #4 (permalink)
Danno
View 89yotarollagts's Photo Gallery
what are you planning on doing ??? are u just rebuilding it ?
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
89yotarollagts is offline   Reply With Quote
Old 11-28-2004, 09:17 PM   #5 (permalink)
Gameroom cash: $134355
just unbolt the 2 bolts for the strut, then the bolt for the control arm and you can get the axle out.... i'm pretty sure that's all i had to do to get the axles out
just remember that there's a 5th mount on the underside of the crossmember
