PCV Valve - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2004, 01:35 PM   #1 (permalink)
Loud Street Machine!
View 89rolla's Photo Gallery
PCV Valve
when i went to take off the filter casing off my carb..i noticed that there were things attached to it like the "PCV Valve" and another small hose that goes into the head..can i go without these things when i change the casing to a cold air intake style with PVC pipe and a cone air filter....
AE92=
89rolla is offline   Reply With Quote
Old 11-28-2004, 10:05 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
You _can_ go without them... but you shouldnt, just find a way to attach the hoses to your new intake tube. I think theres only one hose that goes from the filter housing to the left side of the engine valvecover, the other hose goes to the intake manifold from the right side of the valvecover (PCV valve). The other one is just a inlet to bring in (clean) air inside the valvecover.
Old 11-28-2004, 10:21 AM   #3 (permalink)
so i can take that hose off the top of the block??? it just seems like a vacume hose to the carb casing...but nuthing will come out of it??
is there a way that you can send a pic of your motor..you do have the same type of car as me..
AE92=
Old 11-28-2004, 12:26 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
[img]is there a way that you can send a pic of your motor.[/img]
My motor has more work done to it then just the airfilter ducting, so sending a pic of it would be useless.
As a general idea, both of the hoses have to be connected... What comes out of there is blowby air from the crankcase, which is then burned.
