Originally Posted by ZeroSkillet
Heys guys Im having problems with the aligment on my 1990 Corolla DX Sedan. Well the car used to pull to the right and the steering wheel was to the left side when going foward. We replaced the part for the aligment, sorry but I forgot the name of the piece. I then proceeded to get it aligned. Then it would only pull to the right very little(not noticeable) but now its back to how it started.
Now my question is, could it be the shocks?
They probably replaced your tie rod...Did you get a print out(a must) when they gave you the alignment? most places will guarantee the alignment for a certain time frame, should have taken it back at the first sign of pulling again. also some cars need a four wheel alignment which alot of the "gas stations" don't even do...if the back isn't aligned it throws your front off sort of like a dog walking...also it could be a bent frame, you didn't say how long you had the car before it starting doing this...if you just bought it I would do a vehicle info search to see if your car was ever in a accident...hope this helps
__________________________________________________ _____
"HONK IF ANY PARTS FALL OFF"
