Parts for ae92 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2004, 01:44 PM   #1 (permalink)
View NDR008's Photo Gallery
Parts for ae92
Hi, my AE92 is soon back on the road.
After the new engine, i want to start replacing worn parts and stuff like that.
You know stuff like tires, new shocks, etc.
Till now, bought or ordered are:
OEM front shocks
Tires
Front strut brace
I don't know what to replace/add, I was thinking:
Anti lift plates.
Utahne bushes or what they called.
What else should i concider replacing to start restoring some of the car's original superb road holding and feel?
And most importantly, aprrox cost and form where to source them.
Thanks guys.
You shouldn’t drive for the thrill, but for the pleasure of tasting the control…
NDR008 is offline   Reply With Quote
Old 12-02-2004, 01:46 PM   #2 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
The OEM front strut brace from the coupes are pretty good. And can be had for cheap at the local auto wreckers.
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
Old 12-02-2004, 01:55 PM   #3 (permalink)
Druken Postwhore
TRDragoon's Avatar
View TRDragoon's Photo Gallery
for AE92, the common thing that goes are:
Rear Calipers
clutch master cylinder
clutch slave
fuel/brake line
engine mount
shifter cable
parking cable
flex pipe/exhaust manifold
there so much since its an older car....
The AE92 Master
UniQue_N_RaRe
TRDragoon is offline   Reply With Quote
Old 12-02-2004, 05:05 PM   #4 (permalink)
Yeah that's what i did, i actually got 2, 1 broke when i broke the car :P
the second one i got was in immaculate condition
Old 12-03-2004, 01:28 AM   #5 (permalink)
View ratboycom's Photo Gallery
i make urethane motor mounts but i dont know if i can help you since you dropped that 4efte in there (right?! or did you swap again?) i would get some bigger sway bars off of a levin or sprinter and put them on there or lash two stock ones together
ratboycom is offline   Reply With Quote
Old 12-03-2004, 01:34 AM   #6 (permalink)
Gameroom cash: $134355
Rear Calipers
clutch slave
fuel/brake line
engine mount
shifter cable
parking cable
my ae92 hasn't had ANY of these problems... though, i don't have rear calipers... lol... that's an mk1 mr2 problem too, though... just "rebuild" them yourself.. pretty easy and works great....
i've heard a lot of people (including me) who have had breaking speedometer cables
Old 12-03-2004, 02:03 AM   #7 (permalink)
View Gmann's Photo Gallery
Canada
Hi there....long time reader, first time poster......I have a 92 Camry V6 Le with 200,000KM's on it just recently I'm beginning to feel a bit more vibration in my steering wheel than before, given the age of the vehicle I'm pretty sure the motor mounts are on their way out. I was wondering what you charge for the urethane motor mounts since you live pretty close to me.....If you'd rather discuss this pm that's cool let me know please as I'm interested
Gmann is offline   Reply With Quote
Old 12-03-2004, 10:37 AM   #8 (permalink)
Yes, i have the 4E-FTE engine, so i would need E- series mounts (to be exact the car is a EE90, so parts like the oem strut brace, are actually an upgrade.)
Old 12-03-2004, 05:12 PM   #9 (permalink)
View bob022004's Photo Gallery
Gmann....when was the last time you balanced your tires? Or looked at your CV boots. One of mine was blown and it shot grease all over the inside of the wheel and threw the balance off....cleaned the wheel, rebalanced it and the vibes are gone.
1988 Toyota Corolla GT-S
16V 4A-GE
ACT Stage 1 clutch
bob022004 is offline   Reply With Quote
Old 12-03-2004, 07:50 PM   #10 (permalink)
I'm pretty sure it's no the balancing, as I'm an avid person in doing that every ten thousand km, but it's not excessive and also does it when idling (very slight, most people wouldn't notice it, but I know it just recently appeared). As for CV boots, again the steering wheel very lightly vibrates a bit at idle, and goes away as soon as I start accelerating. Mind you I will take your suggestion and double check everything, but have a strong suspicion it's the motor mounts. Quick question how long does it take to replace and I'm assuming you may as well replace both obviously instead of just one
Old 12-03-2004, 08:01 PM   #11 (permalink)
Druken Postwhore
TRDragoon's Avatar
hehe, i've restored almost everything on my car, i dunno what'll be the next thing to go...im guessing fuel tank, but still solid as is. the only thing next is to pop in a motor
hows your Silvia head light coming along???
The AE92 Master
UniQue_N_RaRe
Old 12-04-2004, 01:11 PM   #12 (permalink)
Gmann i think you might be dead on about the mounts if it does it when idling.
16V 4A-GE
ACT Stage 1 clutch
Old 12-04-2004, 02:34 PM   #13 (permalink)
haven't been working on it much.... i'm trying to get the mr2 close enough to where i can drive it around daily w/o much fuss so that the corolla can go into the garage... need to finish the front end, swap oilpans so i can add the oil cooler, and possibly pull the head and have some work done to it....
Old 12-04-2004, 07:16 PM   #14 (permalink)
well if that vibration bothers you at idle the urethanes will vibrate the chasis pretty badly at idle but they also last a hell of a lot longer, umm i charge about $120 for a set if you send me the stock ones but if you would rather stay stock there are a few junk yards arround my area that have stock mounts for cheap, (trusting that i can find them)
