Making blinkers blink faster - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-03-2004, 09:08 PM   #1 (permalink)
View slammineon95's Photo Gallery
my girlfriend wanted me to make her blinkers blink faster on her 92 corolla. On my neon all i had to do was solder in a new capcitor in the blinker relay. when i looked for her fuses and relays, the only ones i found were under the hood. where are the other fuses and relays located on her 92? I tried LEDs on the neon and that was just a waste of time and money.
slammineon95 is offline   Reply With Quote
Old 12-04-2004, 07:06 PM   #2 (permalink)
View Wolfcastle's Photo Gallery
Capacitors, eh? Clever.
I can't help you make 'em go faster, but if they're really fast it may attracted unwanted attention from LE. They'll assume your fronts (or rears) are broken and may pull you over to cite you.
Wolfcastle is offline   Reply With Quote
Old 12-06-2004, 10:20 PM   #3 (permalink)
where would the relay be for the blinkers?
Old 12-19-2004, 12:54 AM   #4 (permalink)
View karugs's Photo Gallery
Ours has one side blinking faster than the other side. What could cause this?
karugs is offline   Reply With Quote
Old 12-19-2004, 12:58 AM   #5 (permalink)
VVT-i Owns's Avatar
View VVT-i Owns's Photo Gallery
A blown bulb.
- Vince
VVT-i Owns is offline   Reply With Quote
Old 12-19-2004, 01:25 AM   #6 (permalink)
But I see all four lights blinking, indicating no blown bulbs. Will double check tomorrow. Thanks for the quick reply.
Old 12-19-2004, 01:21 PM   #7 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
Originally Posted by VVT-i Owns
A blown bulb.
Couldn't it be a messed up fuse, too?
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 12-19-2004, 02:35 PM   #8 (permalink)
Danno
View 89yotarollagts's Photo Gallery
is this a re post or a revised post from further pages ??? anyways if one side is blinking faster then i might wanna check the resistence on the wires your wires could be going bad and taking the extra power wich in result causes a slower flash also it could be but only true if one bulb is out like on my yota if their is a missing bulb all that extra power goes to the other three and causes a faster flash....... i dunno bout your fuse thery wouldnt the lights quit working all together is the fuse was blown ??
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
89yotarollagts is offline   Reply With Quote
