Foglights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-03-2004, 09:10 PM   #1 (permalink)
View slammineon95's Photo Gallery
Foglights
where have some of you put foglights on whatever generation a 92 is? and also where have you put aftermarket switches? if you have pictures please post them.
slammineon95 is offline   Reply With Quote
Old 12-03-2004, 10:07 PM   #2 (permalink)
Reppin my Home
troy's Avatar
View troy's Photo Gallery
This is a photoshopped pic of my cam with foglights. I ended up adding some real ones after this pic was taken, and there in the present place.. (look at my sig) pretty much below the headlights.
Switches were mounted in an empty DIN below the head unit.
troy is offline   Reply With Quote
Old 12-06-2004, 10:22 PM   #3 (permalink)
anyone else have any suggestions or pics?
Old 12-21-2004, 04:59 PM   #4 (permalink)
what is easiest to do on a 94, hook up a new switch, or hook it up to the parking lights? if i were to hook them up to the parking lights, where would the easiest place be to splice into the wires. please show pics if you have them.
Old 12-21-2004, 06:41 PM   #5 (permalink)
View anuthaCamry's Photo Gallery
Foglights
use a new switch. I'm gonna be doing this project today in my 93. The switch you oughta get is 00550-35946 (or 00550-42966) which is a back-lit OEM toyota switch that you can mount in one of the knockouts by the e-brake.
due to considerations with cali vehicle code I'm gonna make it so it will turn off when the high beams go on and turn back on when they high beams are off.
currently the design should allow for the foglights to be on only when the parking lights are on, actual usage like this may not be legit unless the headlights are on. you can consider tapping either the R-Y or R wires (post fuse headlight common positives) instead of the parking lights, doing so ought to insure that the fogs can only be on when the headlights are on.
CORRECTION, THAT SHOULD BE 00550-35976 OEM
anuthaCamry is offline   Reply With Quote
Old 12-21-2004, 07:09 PM   #6 (permalink)
Gameroom cash: $147537
Old 12-21-2004, 10:02 PM   #7 (permalink)
i just wanted to tap into the parking lights. is there an easier place to tap into it then almost at the bulb?
Old 12-21-2004, 10:48 PM   #8 (permalink)
if you want easy, run a wire directly from the battery positive, into a fuse, into the switch and then back out to the foglamps, and ground the foglamps to a bolt or nut by where they are mounted. if the switch needs to be grounded (like if there is a little light bulb inside it), ground it in the dash.
if you run the foglamps directly off the parking lights you could possibly fry your electrical wiring - not the wires you just installed - but the engine harness.
the reason for the complexity is that the foglamps use a lot of power and the electrical wiring inside the car may not be thick enough to handle all the extra load and may start to get hot like the filament in an electric heater.
if you would like to have them controlled from the parking lamps you need to use an automotive relay. You can power the relay off a tap from the parking lights, but you still need to get power off the battery plus.
-or-
get a foglight installation kit, most of this stuff should be in it already.
good luck!
Old 12-23-2004, 01:38 PM   #9 (permalink)
View ratboycom's Photo Gallery
or like mine
but that took alot of work, and time
The fog is on the inside near the grille (they are JDM levin headlights, if you were wondering)
ratboycom is offline   Reply With Quote
Old 12-23-2004, 02:48 PM   #10 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
I hate people who drive around with foglights thinking its cool, its not, I hate being glared... next time someone comes towards me with foglights on, I'm gonna take aim and play chicken
Old 12-27-2004, 08:56 PM   #11 (permalink)
View karugs's Photo Gallery
What if it was a bulldozer...?
karugs is offline   Reply With Quote
Old 12-28-2004, 02:31 AM   #12 (permalink)
Resident asshole
Flashmn's Avatar
They dont have foglights, they have workinglights and normal drivinglights
Old 12-29-2004, 11:35 AM   #13 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
Cool
Fog lights are fine if their aligned right and make driving at night much more safer...Some places have laws stating that if you have fog lights you must run them at night...The vehicles you should play chicken with are SUV's with HID's, because their higher then regular autos their lights blind you directly with their glare and tint.... .....Raddman
__________________________________________________ __________________
"I'm not afraid to die. I just don't want to be there when it happens"
Raddman is offline   Reply With Quote
Old 12-29-2004, 11:55 AM   #14 (permalink)
Resident asshole
Flashmn's Avatar
Makes it worse actually, because all the light is concentrated at a wide are very close to your bumper, night time that light will prevent you from seeing things clearly at a distance. Basic lighting stuff, you dont see rally cars driving around with foglights in night time races, they have big ass drivinglights.
Old 12-29-2004, 10:49 PM   #15 (permalink)
on this subject, anyone have any experience with the hella/optilux 2020 dual-bulb fog/driving light combo?
