'97 Geo Prizm same engine as a '97 Corolla? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2004, 07:05 AM   #1 (permalink)
View jbattenhouse's Photo Gallery
Hello:
I have a '97 Geo Prizm that has a 1.6L engine. Recently, I have started getting the "clicking starter" syndrome and would like to replace the contacts in it. Is this engine the same as the '97 Corolla 1.6L, meaning would the contacts for a '97 Corolla fit the starter? Also, where are the bolts to take the starter off and how does the small wire from the relay disconnect from the starter? Thanks for any help
jbattenhouse is offline   Reply With Quote
Old 12-06-2004, 07:21 AM   #2 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
Have you looked at the list of links in the Truck section that Sidney posted ? All the starters are similar design. The part #s for almost everything and quite a few tips as well.
CraigW is offline   Reply With Quote
Old 12-06-2004, 08:08 AM   #3 (permalink)
View virtualkuz's Photo Gallery
For all practical purposes a Geo Prism is a Toyota Corolla. Besides trims pieces just about any mechanical piece on a 97 Corolla is going to be the same on your 97 prism.
2005 Corolla XRS Silver Streak Mica
2005 Kawasaki Z750S Candy Plasma Blue
1993 Kawasaki EX500a Luminous Polaris Blue
virtualkuz is offline   Reply With Quote
Old 12-06-2004, 08:11 AM   #4 (permalink)
View cobrajet25's Photo Gallery
A starter "click" on a car that new is probably just the electrical connections on the starter or battery. Unless the car has about a million miles on it, I wouldn't fault the starter right away. Before you gut the starter, make sure your connections are good. If you are sure the starter is bad (most parts stores will test them for free), you might want to just put a new/rebuilt one in. All of the mechanicals between the Corolla and Prism are the same, and the cars are actually made in the same factories. Just squeeze and pull on the relay connector, and it should come off. IIRC, there is one bolt above the starter and one below on the trans bellhousing that hold the starter in. Regards, Aaron
cobrajet25 is offline   Reply With Quote
Old 12-06-2004, 11:49 AM   #5 (permalink)
Moderator
Gameroom cash: $492737
View silver04rollas's Photo Gallery
Prizm to Corolla yesterday was what Pontiac Vibe is to Matrix today.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/H&R Racing/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 12-07-2004, 12:50 PM   #6 (permalink)
Street-Cruiser
Ostornadoe's Avatar
View Ostornadoe's Photo Gallery
If you have a Geo, you can look and a lot of the parts in the engine are Toyota I think all engine parts for the corolla will work on a geo, but the interior and exterior body parts/trim/accesories are not the same, atleast most of them are different anyways.
If everything seems under control, you're just not going fast enough- Mario Andretti
Its not how fast your car goes...its how much nerve the driver has to push it that fast.
Ostornadoe is offline   Reply With Quote
