Gauges on Carburator Car - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2004, 10:32 AM   #1 (permalink)
View gohlex's Photo Gallery
Question Gauges on Carburator Car
Hi guys, i own a 1987 AE91 with 5A-F engine,
i was wondering what are the gauges can be install on a carburator based car?other than
rpm, gas and engine temp gauges
mind to list it out for me, and with the explanation what is the purpose?
i'm a newbie, and still learning here toyota nation
thanks alot 1st yah.
gohlex is offline   Reply With Quote
Old 12-08-2004, 12:40 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
o2 sensor, vacuum gauge, volt, amp, basically everything you could put on an EFI car, you just cant install any gauges/AFC's that interact with an ECU.
Old 12-08-2004, 01:13 PM   #3 (permalink)
View TRDemon's Photo Gallery
Vac gauge - messure the vaccum that is in your cylinders or a
Vac/ boost gauge to messure vac or boost pressure.
Water temp guage.
EGT gauge- Exhaust Gases Temperature.
Fuel Press gauge
Oil pressue
Oil Temperature.
Voltage.
And there is Nitrous pressure
Jayspeed
TRDemon is offline   Reply With Quote
Old 12-08-2004, 01:17 PM   #4 (permalink)
And i forgot Air/Fuel Gauge
Jayspeed
Old 12-08-2004, 01:52 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Vac gauge - messure the vaccum that is in your cylinders or a <- In the manifold actually.
Old 12-09-2004, 09:39 AM   #6 (permalink)
Correct!!!!!!!!!!!!!!
Jayspeed
Old 12-16-2004, 10:18 AM   #7 (permalink)
Water temp guage.
Fuel Press gauge
Oil pressue
Oil Temperature.
Voltage.
may i know what is the purposed of knowing the vaccum pressure in the manifold?the higher and lower value of the pressure could lead to what result
and what about oil pressure too?
sorry for the question, hope someone can guide me.thanks again.
Old 12-16-2004, 11:09 AM   #8 (permalink)
Resident asshole
Flashmn's Avatar
basically a vacuum gauge determines how much suction you have in the manifold. High suction = good economical driving and power.
Old 12-17-2004, 07:36 AM   #9 (permalink)
cool, thanks for the info man!
Old 12-17-2004, 10:04 PM   #10 (permalink)
View boosted gt's Photo Gallery
autometer also makes a clock that looks like a gauge
84 AE86 corolla SR-5 (sold)
89 toyota corolla sedan auto 217k (sold for $250 )
90 celica st auto 216k and counting
87 merkur XR4TI only 100k cause it never runs
00 crown vic P71 police interceptor 162k
boosted gt is offline   Reply With Quote
Old 12-18-2004, 01:55 PM   #11 (permalink)
Resident asshole
Flashmn's Avatar
yeah, which West coast customs installed to the 240SX on pimp my ride, sheesh
Old 12-19-2004, 07:07 PM   #12 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
hey.. as long as you're not putting in a "BOOST GAUGE" on your NA car, then any gauge should work.
Old 12-20-2004, 12:33 AM   #13 (permalink)
Resident asshole
Flashmn's Avatar
well you could use the boost gauge to monitor vacuum aswell.
Old 12-20-2004, 03:34 PM   #14 (permalink)
i just install my Rich/Lean guage and i already install a Vac/Boost. And i check and see if everything is connected properly as far as i see my car seems to be running pretty good. But i'm monitor the Rich/lean very closely because when i charge the engine I wouldn't want that red light showing up on the lean part . so when the the vac/boost guage goes up just before boost the rich/lean guage is on the green side (meaning rich) with i think is very improtant and pretty good so far. So guys the the gauges installation was a success but i i would like to install a oil press and a water temp just to be on the safe side. what you guys think???
Jayspeed
